GATT BLE variable array formatting?
Loosedoglew
Postby Loosedoglew » Sun Mar 31, 2019 6:44 pm
Hello people of the internet, first ever post on here!
I'm building a BLE client that will hopefully advertise a few GATT services on an ESP32, so far I've got a couple of services working successfully like battery and temperature, with each one on it's own service.
I've already got a few working that have fixed length structures, such as: cycling_power, Sensor_location (0x2A5D) an unsigned 8 bit int. But other characteristics like 'Cycling Power Measurement' have a 'variable length structure containing a Flags field' and I'm not sure how to tackle these.
I will include screenshots from nRF connect app during some reverse engineering attempts I've made. You can see in the value field in the 5th and 6th hexadecimal places that the value increased when I cycled from 0 to 100 watts.
https://ibb.co/fvW9kty
https://ibb.co/8my0QsP
cyclingPower.setValue(powerMeasurmentStructure);
      cyclingPower.notify();
What type should I assign for powerMeasurmentStructure and can setValue be used? Any existing examples would be great!
Thanks in advance!
Louis
chegewara
Re: GATT BLE variable array formatting?
Postby chegewara » Fri Apr 05, 2019 4:19 am
https://www.bluetooth.com/specification ... rement.xml
You have to build struct and then just send an array of uint8 values.
Loosedoglew
Postby Loosedoglew » Tue Apr 09, 2019 11:13 pm
Hello, thanks for the reply!
I've just completed a crash course in structs and after consulting the bottom of the page (.xml) table, that details the order of MSB to LSB I'm still unsure how to format the size in
characteristic.setValue(data, size);
Do you have any advice or links to an example I could try, I'm struggled to find anything on notifying using BLE of variable length structure.
Users browsing this forum: No registered users and 103 guests
