Access global object in call of function pointer
Kasperdelasopa
Postby Kasperdelasopa » Fri Mar 29, 2019 10:20 am
i'm using function pointers to dynamically call functions.
I have created a global object to store some settings in it.
class Settings{
	public:
			Settings();
			std::string getID();
	private:
			std::string ID;
I define a object like this globally :
Settings *_settings;
setup(){
_settings = new Settings();
Serial.println(_settings->getID().c_str()); //PointA
void functionCalledFromPointer(){
Serial.println(_settings->getID().c_str()); //PointB
At PointA the content is printd correctly.
At PointB the content is emtpy.
What can i do to have the global objetc correctly accessable?
Best regards
idahowalker
Re: Access global object in call of function pointer
Postby idahowalker » Fri Mar 29, 2019 9:11 pm
Perhaps change this:
setup(){
to this:
setup(){
When the object is created inside of setup the objects scope is defined within setup. When the object is defined global, the object is accessible global.
Kasperdelasopa
Postby Kasperdelasopa » Sun Mar 31, 2019 9:00 am
Actually i could solve it by just using std::string instead of const char* all over the place
But Thanks
Users browsing this forum: Majestic-12 [Bot] and 115 guests
