hello everyone,
My company is trying to use ESP32 in the project. We use IMX6 controller which is connected to ESP32-WROOMD through UART pins.
So as per my understanding I can use the functionality of ESP32 bluetooth and Wifi through AT commands.
It seems bit difficult to discover nearby ble services and characteristics and connect to it using AT command.
Is there any other way I can do it using UART interface?
Amd if not are there any example code of BLE?
Regards,
Asma
Interface other than AT command through UART IO
Re: Interface other than AT command through UART IO
Maybe you can follow the BLE example on GitHub to run the BLE AT commands.
ok. but is there any other method I can work on this?
