ESP32 Stepper Nema17 Charging-LED lights up when motor stops
DirtyStiletto
Postby DirtyStiletto » Wed Feb 27, 2019 9:45 pm
Hello, everybody.
I connected a Nema 17 motor to the ESP32 using the "Sparkfun ESP32 Power Control Shield".
As soon as the motor stops, the charging LED of the ESP32 flashes and the voltage drops.
If I use a Nema 14 motor, the Scetch works fine.
Nema 14:
https://jkongmotor.en.made-in-china.com ... -2804.html
Nema 17:
https://www.banggood.com/100mm-Long-Sta ... rehouse=CN
Power Control Shield:
https://www.sparkfun.com/products/14155
ESP_Sprite
Re: ESP32 Stepper Nema17 Charging-LED lights up when motor stops
Postby ESP_Sprite » Thu Feb 28, 2019 2:05 am
Do you use the same power supply to power the ESP32 and the motor shield? If so, your power supply may be underdimensioned. Steppers can eat up an awful amount of power when started.
Users browsing this forum: No registered users and 81 guests
