Getting stack overflow error reboots with a larger char array size
Askingman
Postby Askingman » Sun Feb 24, 2019 10:39 am
Hello.
I am new to arduino/esp32 programming and am stuck on a strange (at least to me) issue.
Basically, I have the esp32 running in a soft AP mode with the webServer module running on it and use it to serve basic webpages.
I followed an example tutorial for making the sketch and it works fine, the problems start, when I need to return longer amounts of text. In fact I think the problem has probably nothing to do with the webserver part, but rather with the part of the code where fill the char arrays up with text.
I define a bunch of char arrays like this:
    char replyHTML[9000];
    char setupForm[5000];
    char sslCert[3000];
And then fill them up with run of the mill functions like sprintf and preferences.getString.
At first, the ESP32 was just rebooting without any errors, so I reduced the size of the char arrays by a bit and the ESP32 was still rebooting, but this time around it started printing out the following error:
***ERROR*** A stack overflow in task loopTask has been detected.
abort() was called at PC 0x4008f910 on core 1
So I reduced the size of the char arrays once more and this time, the code worked flawlessly with no reboots.
The problem is, that I that I need to fit about 10000 - 15000 characters combined into the char arrays above.
This can't be a memory problem, because when I upload the code, the editor reports "....leaving 284292 bytes for local variables" and the about 15000 characters I need in total is not much more than 15KB, so there should be plenty of space.
Thank you for any advice.
ESP_Dazz
Re: Getting stack overflow error reboots with a larger char array size
Postby ESP_Dazz » Mon Feb 25, 2019 1:35 pm
That's probably because you're declaring these within the void loop() meaning thus goes onto the loopTask's stack which is only around 8K bytes.
Try one of the following:
1) Declaring the arrays as a global
char sslCert[3000];
2) Declaring the arrays as static within the loopTask
    static char replyHTML[9000];
    static char setupForm[5000];
    static char sslCert[3000];
3) Allocating the arrays on the heap using malloc
    char *replyHTML = (char *)malloc(sizeof(char) * 9000);
    char *setupForm = (char *)malloc(sizeof(char) * 5000);
    char *sslCert = (char *)malloc(sizeof(char) * 3000);
idahowalker
Postby idahowalker » Mon Feb 25, 2019 6:28 pm
If you are running with freeRTOS taskings then increase the stack size of the task.
put this code at the bottom of the task:
         Serial.print( "fAlarm " );
         Serial.print(uxTaskGetStackHighWaterMark( NULL ));
         Serial.println();
         Serial.flush();
to get an idea of the how the task is doing with the current task size and adjust stack size accordingly.
Users browsing this forum: lbernstone and 106 guests
