Can esptool.py be used to copy a text file to/from the flash?
I found the command "write_flash" but that is used to write a binary blob to flash.
Can esptool.py be used to write text file to flash?
Re: Can esptool.py be used to write text file to flash?
Yes. "esptool.py write_flash" will write whatever bytes are found in the file(s) given. They are written to the offsets in the flash which are also given.[*] So you can write a binary file, a text file or any other kind of file.
[*] There is one exception, which is if you flash a file to offset 0x1000 - the bootloader offset - then esptool.py may manipulate the header of this file to set flash speed, flash size or flash mode depending on the command line arguments. But writing to any other offset, what is written will be 1:1 the same file contents.
Great.
May I know what offset should I use to write_flash? Example, what offset should I use so that I do not overwrite existing data? Does "write_flash" function auto-detect the next available offset to start writing? Is there a function I should run before write_flash so that I can see the next available offset?
Below are what i think are the attributes of args for "write_flash" optional arguments, and "write_flash" possible values and defaults. Am I correct?
What is args.no_stub?
Attributes Possible Values Default Value
args.erase_all True,False True
args.flash_freq keep,40m,26m,20m,80m ?
args.flash_mode keep,qio,qout,dio,dout ?
args.flash_size 1MB,2MB,4MB,8MB,16M args.size
+ESP8266-only 256KB,512KB,2MB-c1,4MB-c1
args.spi_connection ESP32-only argument. None?
SPI, HSPI or [CLK,Q,D,HD,CS]
args.no_progress True,False True
args.verify True,False True
args.compress True,False None else if args.no_stub ?
args.no_compress True,False ?
Users browsing this forum: No registered users and 341 guests
