Kernel panic using RH_ASH library
tomxygen
Postby tomxygen » Mon Jan 28, 2019 8:07 pm
I'm using a 433Mhz transmitter and receiver to send data from an Arduino nano to an ESP32, using the RH_ASK library, a sublibrary of RadioHead.
The problem is that as long as I use the sample sketch, everything works fine, but when I implement the library into my project, when I add the instruction driver.init(); I run into a kernel panic in the serial monitor:
Guru Meditation Error: Core  1 panic'ed (Cache disabled but cached memory region accessed)
Guru Meditation Error: Core  1 panic'ed (IllegalInstruction). Exception was unhandled.
Memory dump at 0x40146164: bad00bad bad00bad bad00bad
Guru Meditation Error: Core  1 panic'ed (IllegalInGuru Meditation Error: Core  1 panic'ed (Unhandled debug exception)
Debug exception reason: Stack canary watchpoint triggered (loopT	@4)
What can I do?
idahowalker
Re: Kernel panic using RH_ASH library
Postby idahowalker » Tue Jan 29, 2019 5:50 pm
https://docs.espressif.com/projects/esp ... rrors.html
Most likely, you may have to edit the library to work with ESP32.
Do you have debug enabled? There should be more information available for a Guru error.
tomxygen
Postby tomxygen » Sat Feb 02, 2019 4:50 pm
how can I enable the debug mode?
idahowalker
Postby idahowalker » Sun Feb 03, 2019 1:26 am
Arduino IDE | Tools | Core Debug Level and make selection.
tomxygen
Postby tomxygen » Mon Feb 04, 2019 8:45 pm
Here is the output in verbose mode
[V][esp32-hal-i2c.c:1442] i2cInit(): num=0 sda=27 scl=26 freq=0
[V][esp32-hal-i2c.c:1643] i2cSetFrequency(): Fifo threshold=3
[V][esp32-hal-i2c.c:1643] i2cSetFrequency(): Fifo threshold=15
Memory dump at 0x40146c54: bad00bad bad00bad bad00bad
Debug exception reason: Stack canary watchpoint triggered ()
Users browsing this forum: No registered users and 95 guests
