Flow Switch to ESP-32S
hafiz.iot
Postby hafiz.iot » Mon Jan 14, 2019 10:31 am
Help me to code my flow switch (YF-S201), i tried this code works on arduino mega 2560, but why not worked here?
this is my code found in internet
volatile int flow_frequency; // Measures flow sensor pulses
unsigned int l_hour; // Calculated litres/hour
unsigned char flowsensor = 23; // Sensor Input
unsigned long currentTime;
unsigned long cloopTime;
void flow () // Interrupt function
flow_frequency++;
void setup()
pinMode(flowsensor, INPUT);
digitalWrite(flowsensor, HIGH); // Optional Internal Pull-Up
attachInterrupt(0, flow, RISING); // Setup Interrupt
sei(); // Enable interrupts
currentTime = millis();
cloopTime = currentTime;
void loop ()
// Every second, calculate and print litres/hour
if(currentTime >= (cloopTime + 1000))
cloopTime = currentTime; // Updates cloopTime
// Pulse frequency (Hz) = 7.5Q, Q is flow rate in L/min.
l_hour = (flow_frequency * 60 / 7.5); // (Pulse frequency x 60 min) / 7.5Q = flowrate in L/hour
flow_frequency = 0; // Reset Counter
Serial.print(l_hour, DEC); // Print litres/hour
Serial.println(" L/hour");
also, i tried this worked too
int TURBINE; //pengukuran SINYAL data yang bersifat incremental
int HSensor = 23; //nama alias pada pin 2
int Calc;
void speedrpm () //fungsi penghitungan dan interrupt
TURBINE++; //bersifat incrementing (dengan mode falling edge)
void setup()
pinMode(HSensor, INPUT); //inisialisasi sebagai input
attachInterrupt(0, speedrpm, RISING); //cara penulisan perintah interrupt
void loop ()
TURBINE = 0; //data awal = 0
sei(); //perintah aktifnya mode interrupt
delay (1000); //nilai delay 1 detik
cli(); //perintah untuk matinya program interrupt
Calc = (TURBINE * 60 / 7.5); //Pulsa * 60 / 7.5
//satuan FLOW RATE benda cair yaitu L / hour
Serial.print(Calc, DEC); //menampilkan hasil pembacaan kalkulasi flow rate dalam bentuk dec di serial monitor
Serial.print(" L/hour\r\n"); //Tampilkan L / hour pada baris baru
ESP_Sprite
Re: Flow Switch to ESP-32S
Postby ESP_Sprite » Wed Jan 16, 2019 8:18 am
Moved to the Arduino subforum, as you seen to use that. Furthermore, it helps if you tell us how it 'does not work', and what you already tried wrt debugging.
Users browsing this forum: No registered users and 88 guests
