ESP32 DEV KIT v4 MODULE WiFi Disconnect Problem
ysadik
Postby ysadik » Mon Dec 31, 2018 7:34 am
hello,
I'm working on ESP32 Dev Kit v4 module and I have a problem. After ESP32 connect to our wifi , it was disconnected in a few minute.
How can I solved these problem? Why is ESP32 reason to disconnect? I began to start stabil but after 10 min or 20 min module was disconnected. Could someone help me?
martinius96
Re: ESP32 DEV KIT v4 MODULE WiFi Disconnect Problem
Postby martinius96 » Mon Dec 31, 2018 2:26 pm
Post your source code please
ysadik
Postby ysadik » Wed Jan 02, 2019 6:50 am
void setup()
          WiFi.begin(ssid, password);
       if(WiFi.status() != WL_CONNECTED)
           Serial.print(".");
           digitalWrite (greenpin,LOW);
           replay = true;
       else if (WiFi.status() == WL_CONNECTED && replay == true  )
           Serial.println("IP address: ");
           replay = false;
           Serial.println(ssid);
           digitalWrite (greenpin,HIGH);
Edje11
Contact:
Postby Edje11 » Wed Jan 02, 2019 10:49 am
Print the wifi status to see what the problem is.
           Serial.print(WiFi.status());
           Serial.print(".");
           replay = true;
           replay = false;
ysadik
Postby ysadik » Fri Jan 04, 2019 6:22 am
Thank you for suggest but I tried and I can not see anything. Also module was look like disconnect wifi but program continue to work background.
Users browsing this forum: No registered users and 76 guests
