can't fread files created using mkspiffs
gongli
Postby gongli » Fri Dec 21, 2018 9:15 am
Hi, I was reading zero byte for files created using mkspiffs (https://github.com/igrr/mkspiffs.git)
How I make the file system image
mkspiffs -d 5 -c res/ -b 4096 -p 256 -s 0xF0000 spiffs.bin
How I flash it
python esptool.py --chip esp32 --baud 912600 write_flash -z 0x210000 spiffs.bin
How are the partitions
nvs,      data, nvs,     0x9000,  0x6000,
phy_init, data, phy,     0xf000,  0x1000,
factory,  app,  factory, 0x10000, 2M,
storage,  data, spiffs,  ,        0xF0000,
The size of flash is 4MB. Besides the problem above, I was able to list the file system. And ftell() correctly tells the file's size, which is great than zero. Also, I was able to create new file on the file system using fopen(), and reading the newly created file was no problem. Thanks if someone can point me out what was going wrong.
ESP_igrr
Re: can't fread files created using mkspiffs
Postby ESP_igrr » Fri Dec 21, 2018 11:20 am
Please check this topic: https://www.esp32.com/viewtopic.php?t=6336
https://github.com/igrr/mkspiffs/issues/48
https://github.com/igrr/mkspiffs/blob/m ... figuration
Also please compare the output of mkspiffs --version with your spiffs settings in sdkconfig.
gongli
Postby gongli » Mon Dec 24, 2018 3:17 am
Thanks. It works now.
Users browsing this forum: No registered users and 94 guests
