readdir cause panic on 16MB spi flash board
gongli
Postby gongli » Fri Dec 21, 2018 3:30 am
I have an ESP32-WROVER-B module with 16MB flash partitioned as follows:
nvs,      data, nvs,     0x9000,  0x4000,
otadata,  data, ota,     0xd000,  0x2000,
phy_init, data, phy,     0xf000,  0x1000,
factory,  0,    0,       0x10000,  2M,
ota_0,    0,    ota_0,   0x210000, 2M,
ota_1,    0,    ota_1,   0x410000, 2M,
storage,  data, spiffs,  0x610000, 0x9F0000,
The lart part is a spiffs partition and was formatted automatically at first boot. And my app can write file to it without error. However, when doing a dir list, it causes panic like follows:
Guru Meditation Error: Core  0 panic'ed (Cache disabled but cached memory region accessed)
Core 0 register dump:
PC      : 0x400d7110  PS      : 0x00060034  A0      : 0x40084e30  A1      : 0x3ffb0690
A2      : 0x3ffb1144  A3      : 0x3ffc2350  A4      : 0x3ff42000  A5      : 0x40095754
A6      : 0x00000000  A7      : 0xffffcffb  A8      : 0x800855d1  A9      : 0xe0020c00
A10     : 0xe0020800  A11     : 0x00000000  A12     : 0x8008f4e5  A13     : 0x3ffcb880
A14     : 0x00000000  A15     : 0x3ffcb8b0  SAR     : 0x00000017  EXCCAUSE: 0x00000007
EXCVADDR: 0x00000000  LBEG    : 0x40098b10  LEND    : 0x40098b3e  LCOUNT  : 0x00000000
Core 0 was running in ISR context:
EPC1    : 0x4008f67a  EPC2    : 0x00000000  EPC3    : 0x00000000  EPC4    : 0x400d7110
Backtrace: 0x400d7110:0x3ffb0690 0x40084e2d:0x3ffb06b0 0x4008f677:0x00000000
CPU halted.
My code running there was calling
readdir(...)
. From the core dumps above, it seems panic happens running inside
esp_rom_spiflash_read_data
The app runs the code without error on 4MB flash module (with partitions properly laid for 4MB size). I was wondering how the 16MB flash case fails. Any help will be highly appreciated!
ESP_igrr
Re: readdir cause panic on 16MB spi flash board
Postby ESP_igrr » Fri Dec 21, 2018 3:46 am
Hi gongli, thanks for reporting this. Could you please use idf_monitor (or gdb) to decode the rest of the call stack?
https://docs.espressif.com/projects/esp ... -backtrace
The exception seems to happen inside an interrupt, so perhaps you have some interrupt handler which calls a function which is not in IRAM, and at the same time the interrupt handler is registered with ESP_INTR_FLAG_IRAM.
gongli
Postby gongli » Fri Dec 21, 2018 6:57 am
Indeed, there is one simple wraper function missing IRAM decorator actually called by my ISR. Thus cause the panic. Though, it works pretty well on my 4MB board.
Thank you sir, igrr, for help me find it out.
Users browsing this forum: No registered users and 98 guests
