WiFi and BLE UART bridging Exception
biccius
Postby biccius » Tue Dec 11, 2018 12:08 pm
Hello
I'm trying to develop a "UART to BLE" and "UART to WIFI" bridge application on a ESP32-WROOM.
I'm using Arduino core 1.0.0 stable package available here
My application is the following:
#include <EEPROM.h>
#include "Arduino.h"
#include <BLEDevice.h>
#include <BLEServer.h>
#include <BLEUtils.h>
#include <BLE2902.h>
#include <WiFi.h>
// UART: Serial1
#define UART_BR                    115200
#define UART                     Serial
std::string rxValue;        // RX STRING VALUE received from BLE
BLEServer           * pServer             = NULL;
BLECharacteristic * pTxCharacteristic    = NULL;
BLEService           * pService             = NULL;
bool                 deviceConnected     = false;
bool                 oldDeviceConnected  = false;
#define SERVICE_UUID           "49535343-fe7d-4ae5-8fa9-9fafd205e455" // UART service UUID
#define CHARACTERISTIC_UUID_TX "49535343-1e4d-4bd9-ba61-23c647249616"
#define CHARACTERISTIC_UUID_RX "49535343-8841-43f4-a8d4-ecbe34729bb3"
int countBytes = 0;
uint8_t RXbuffer[256];
uint8_t TXbuffer[256];
class MyServerCallbacks: public BLEServerCallbacks
    void onConnect(BLEServer* pServer)
      deviceConnected = true;
    void onDisconnect(BLEServer* pServer)
class MyCallbacks: public BLECharacteristicCallbacks
    void onWrite(BLECharacteristic *pCharacteristic)
      rxValue = pCharacteristic->getValue();
      if (rxValue.length() > 0)
                 for(int i=0; i < rxValue.length(); i++)
                    TXbuffer[i] = rxValue[i];
                UART.write(TXbuffer,rxValue.length());
const char* ssid     = "ESP32-Access-Point";
const char* password = "123456789";
WiFiServer server(1001);
uint8_t byte_STATE = 0;
static uint8_t lastPinState;
BLEDevice *bleDevice;
uint8_t pinState;
void setBLE()
      UART.println("Init BLE...");
      // Create the BLE Device
      //BLEDevice::init("FORTEST-ESP32-BLE");
     bleDevice->init("FORTEST-ESP32-BLE");
      // Create the BLE Server
      pServer = BLEDevice::createServer();
      pServer->setCallbacks(new MyServerCallbacks());
      // Create the BLE Service
      pService = pServer->createService(SERVICE_UUID);
      // Create a BLE Characteristic
      pTxCharacteristic = pService->createCharacteristic(
                                            CHARACTERISTIC_UUID_TX,
                                            BLECharacteristic::PROPERTY_NOTIFY
      pTxCharacteristic->addDescriptor(new BLE2902());
      BLECharacteristic * pRxCharacteristic = pService->createCharacteristic(
                                                 CHARACTERISTIC_UUID_RX,
                                                BLECharacteristic::PROPERTY_WRITE
      pRxCharacteristic->setCallbacks(new MyCallbacks());
      // Start the service
      pService->start();
      // Start advertising
      pServer->getAdvertising()->start();
void setWIFI(){
     UART.println("Init WIFI...");
     WiFi.softAP(ssid, password);
     server.begin();
//The setup function is called once at startup of the sketch
void setup()
    UART.begin(115200);
    EEPROM.begin(1);
    byte_STATE = EEPROM.read(0);
    lastPinState = byte_STATE;
    pinMode ( 5 , INPUT_PULLUP);
    if(byte_STATE == 0)
        // BLE
        setBLE();
    }else
        // WIFI
        setWIFI();
// The loop function is called in an endless loop
void loop()
       pinState = digitalRead(5);
        if(!pinState && lastPinState)
           //UART.println("Button pressed!");
              byte_STATE = !byte_STATE;
           EEPROM.write(0,byte_STATE);
           EEPROM.commit();
           delay(100);
           //UART.print("byte_STATE = ");
           UART.println(byte_STATE);
           delay(100);
           ESP.restart();
        lastPinState = pinState;
        switch (byte_STATE)
            case 0:
            {    // BLE
                                // connected
                                if (deviceConnected)
                                    countBytes = UART.available();
                                    while (countBytes>=20)
                                        UART.readBytes(RXbuffer, 20);
                                        pTxCharacteristic->setValue(RXbuffer,20);    // tx to BLE
                                        pTxCharacteristic->notify();
                                        countBytes-=20;
                                    if (countBytes > 0) // rx from UART
                                        UART.readBytes(RXbuffer, countBytes);
                                        pTxCharacteristic->setValue(RXbuffer,countBytes);    // tx to BLE
                                // disconnecting
                                if (!deviceConnected && oldDeviceConnected)
                                    //UART.println("DISCONNECT!");
                                    delay(500);
                                    pServer->startAdvertising(); // restart advertising
                                    oldDeviceConnected = deviceConnected;
                                    //rxValue.clear();
                                    //UART.flush();
                                // connecting
                                if (deviceConnected && !oldDeviceConnected)
                                    //UART.println("CONNECTED!");
                                    //rxValue.clear();
                                    //UART.flush();
            case 1:
                // WIFI
                                WiFiClient client = server.available();   // Listen for incoming clients
                                  if (client)
                                  {                                         // If a new client connects,
                                    //Serial.println("New Client.");          // print a message out in the serial port
                                    while (client.connected())
                                    {                                        // loop while the client's connected
                                      if (client.available()) {             // if there's bytes to read from the client,
                                            // read a byte, then
                                        UART.write(client.read());                    // print it out the serial monitor
                                          if (UART.available())
                                            if (client.connected()) client.write(UART.read());
            default:
The application is very simple:
- At the startup an EEPROM address is read
- If a 0 value is read a BLE/UART bridge will run
- If a 1 value is read a WIFI/UART bridge will run
Now forget about the various obvious optimizations of the code.
My problem is that with the two bridges enabled i get the following errors when i start the application
ets Jun  8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:952
load:0x40078000,len:6084
load:0x40080000,len:7936
entry 0x40080310
Fatal exception (0): IllegalInstruction
epc1=0x4008033d, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
messages changes after every hardware reset
others errors are the following
entry 0x40080310
Fatal exception (28): LoadProhibited
epc1=0x400368b8, epc2=0x00000000, epc3=0x00000000, excvaddr=0x000008f7, depc=0x00000000
entry 0x40080310
epc1=0x40080338, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
(also StoreProhibited...)
If function call "setBLE()" is commented the application start the BLE/UART bridging without problems
If function call "setWIFI()" is commented the application start the WIFI/UART bridging without problems
Can it be a problem due to the lack of RAM?
Any suggestion is welcome
Fabrizio
chegewara
Re: WiFi and BLE UART bridging Exception
Postby chegewara » Wed Dec 12, 2018 11:11 pm
The logs are not very helpful here, but seems you can run your app by commenting out function invocation, then why dont you try to comment out line by line in that function and see where is the cause?
biccius
Postby biccius » Thu Dec 13, 2018 8:43 am
chegewara wrote: The logs are not very helpful here, but seems you can run your app by commenting out function invocation, then why dont you try to comment out line by line in that function and see where is the cause?
Thank you for the suggestion
I've enabled BLE and WIFI
 if(byte_STATE == 0)
        // BLE
        setBLE();
    }else
        // WIFI
        setWIFI();
if in WiFi i comment this line for example, the application starts correctly
Obviously WiFi won't start
Is it therefore possible that it is a memory allocation problem?
If yes, can someone tell me about threads or suggestions to try and solve this problem?
Fabrizio
biccius
Postby biccius » Wed Dec 19, 2018 3:54 pm
Solved changing partion scheme from "Default" to "No OTA (Large APP)"
Thread can be closed
Users browsing this forum: No registered users and 100 guests
