I am building a weather station with all kinds of sensors, SD card etc. When the program is running it results in a reported free heap of only 114 kB. OTA does not work anymore but when I run the example BasicOTA, it works. The OTA code in my program is copy / paste from that example. Could it be that there is a minimum of RAM needed in order to let OTA work? And if so, how much is it?
Somewhat related to this: in Arduino and ESP8266 programs I was able to release a lot of memory by not using Serial.begin(), .print() etc. after debugging is done by using
#define DEBUG
#ifdef DEBUG
#define SP(x) Serial.print(x)
#define SPl(x) Serial.println(x)
#else
#define SP(x) {}
#define SPl(x) {}
#endif
and
#ifdef DEBUG
#endif
That does not seem to make any difference in ESP32. Is that correct?
Thanks in advance for your advice.
Minimum heap necessary for OTA?
Re: Minimum heap necessary for OTA?
I moved the SC card initialisation part out of setup() into a function so it only gets loaded when needed. I also disabled Bluetooth and reclaimed its memory so now I am north of 220 kB free again. OTA works fine now. It would be nice to know the minimum required, though.
And I still wonder about Serial, not freeing up memory when not used. Any ideas?
Users browsing this forum: No registered users and 32 guests
