ESP32-WROOM-32U Wi-Fi Tx/Rx pin numbers
david711205
Postby david711205 » Tue Nov 20, 2018 3:27 am
What are Wi-Fi Tx/Rx pin numbers for ESP32-WROOM-32U Wi-Fi Tx/Rx pin numbers?
I cannot see from data sheet.
ESP_Sprite
Re: ESP32-WROOM-32U Wi-Fi Tx/Rx pin numbers
Postby ESP_Sprite » Tue Nov 20, 2018 4:34 am
"WiFi TX/RX"? What do you mean? There are UART TX and RX pins; these are well-indicated. There's also an antenna connection that multiplexes Rx and Tx RF signals; that doesn't have a pin but an U.fl connector.
david711205
Postby david711205 » Tue Nov 20, 2018 5:13 am
If we use RF switch to implement multi-antenna selection, how do I do to connect ESP32-WROOM-32U to RF switch?
ESP_Sprite
Postby ESP_Sprite » Tue Nov 20, 2018 7:28 am
Using the RF antenna connector.
Users browsing this forum: No registered users and 69 guests
