Send data App to esp32
neo888
Postby neo888 » Tue Oct 23, 2018 8:23 pm
Hi everybody!
I ask your help because it's been a while since I can not find the solution.
my project is to make an aerothermal panel with autonomous management (esp32). I am at the stage where I created a wifi access point server with the Asyncwebserver method.
I can get on my smartphone information esp32 and I show them in the app.
Only the app is also used to change the thermostat setpoint via 2 buttons. This is where I can not recover this value when one of the two buttons is pressed.
In my head, I see things like this:
info_pan (esp32) -> Server -> app
For this one, in the setup () I insert the function:
server.on ("/ esp32", HTTP_GET, [] (AsyncWebServerRequest * request)
              {request-> send (200, "text / plain", info_pan);});
And in loop(), i update info_pan when values change.
But how i must do for retrieve value of thermostat in the direction :
thermostat_update(app) -> Server -> esp32
i tried a lot of solutions but i don't find the good.
the method that I thought was good was:
in the setup():
server.on ("/ app", HTTP_GET, [] (AsyncWebServerRequest * request)
              {request-> send (200, "text / plain", thermostat_update);});
and in loop()
thermostat_update=getrequest(/app)?
I don't arrive to formulate the request.
I need a concrete example. I found examples with html pages but I think it's different in syntax.
maybe the solution?
thank you for taking the time to read my problem
#include <OneWire.h>                         // Gestion des ds18b20 sur 1 bus
#include <DallasTemperature.h>               // Récupération des infos des ds18b20
#include <CheapStepper.h>                    // Gestion du moteur pas à pas 28BYJ-48 5v ( p=64 et p/tr=64 )
#include <WiFi.h>                            // Pour l'utilisation du WiFi et la création du point d'accès
#include <ESPAsyncWebServer.h>               // Pour la création du serveur HTTP
//#include <FS.h>
//#include <AsyncTCP.h>
/***  --------------------------------------------  WIFI  -------------------------------------------  ***/
const char *ssid = "PAN_1";                  // Déclaration du nom du réseau (SSID)
const char *password = "12345678";           // Et de son mot de passe (dans le cas où il est crypté
AsyncWebServer server(80);                   // Port par défaut d'un serveur HTTP
String info_pan = "";                        // Récupère toutes les données à envoyer à l'application
String thermostat_update = "23.00";          // Récupère l'actualisation du thermostat par l'application
/***  --------------------------------------------  TEMP  -------------------------------------------  ***/
OneWire ds(13);                              // Pin digital sur lequel sont connectées toutes les DS18B20
DallasTemperature sensors(&ds);              // Fonction de récupération des données des DS18B20
DeviceAddress inDS = { 0x28, 0x7E, 0x1C, 0x39, 0x06, 0x00, 0x00, 0xC2 };  //Adresses uniques des ds18b20
DeviceAddress outDS = { 0x28, 0xA5, 0xE7, 0xDD, 0x06, 0x00, 0x00, 0x6F }; //récup : one_wire_address_finder
DeviceAddress panDS = { 0x28, 0xB3, 0xF8, 0x3A, 0x06, 0x00, 0x00, 0x5A };
float Tpan = 0;                              // Température du panneau
float Tout = 0;                              // Température extérieure
float Tin = 0;                               // Température intérieure
float TH = 23.0;                             // Valeur par défaut du thermostat
int HUM = 0;                                 // Capteur Humidité
/***  --------------------------------------------  FAN  --------------------------------------------  ***/
#define CHANNEL_FAN_PWM     0                // Le canal pwm. Il y a 16 canaux (0-15)
#define RES_BIT             8                // La résolution (8bits)
#define BASE_FREQ           12000            // La fréquence de base en Hz
#define PIN_FAN_PWM         16               // Port sur lequel est connecté la broche pwm du ventilateur
int PWM = 0;                                 // Vitesse du ventilateur (0-255)
String ETAT = "Arrêt";                       // Etat du ventilateur : Marche/Arrêt
/***  --------------------------------------  MOTEUR PAS A PAS  -------------------------------------  ***/
CheapStepper stepper;                        // Variable récupérant la valeur du pas du moteur
boolean moveClockwise = true;                // Variable définissant le sens de rotation du moteur
/***                                         ledcAnalogWrite()                                         ***/
uint32_t min(uint32_t num1, uint32_t num2){ if(num1 < num2){ return num1; }else{ return num2; } }
void ledcAnalogWrite(uint8_t channel, uint32_t value, uint32_t valueMax = 255)
  uint32_t duty = (255 / valueMax) * min(value, valueMax);  // pour calculer duty, 255 = 2 ^ 8bits - 1
  ledcWrite(channel, duty);                                 // enregistre la valeur de duty
/********************                              SETUP()                            ********************/
void setup()
  Serial.begin(115200);                      // Activation de la liaison série
  WiFi.softAP(ssid, password);               // Appel de la fonction de création du réseau AccessPoint
  Serial.println(WiFi.softAPIP());           // Affichage de l'adresse IP de l'ESP32
  sensors.begin();                           // Activation des sondes DS18B20
  sensors.setResolution(panDS, 11);          // On précise que la résolution 'r' des sondes sera de 11 bits
  sensors.setResolution(outDS, 11);          // 9: r=0.5°C, 10: r=0.25°C, 11: r=0.125°C, 12: r=0.0625°C
  sensors.setResolution(inDS, 11);           // Mais la précision sera pour tous +/- 0.5°C
  pinMode(PIN_FAN_PWM, OUTPUT);              // Paramétrage du sens de communication du pin du ventilateur
  ledcSetup(CHANNEL_FAN_PWM, BASE_FREQ, RES_BIT);                  // Paramétrage PWM
  ledcAttachPin(PIN_FAN_PWM, CHANNEL_FAN_PWM);
  server.on("/esp32", HTTP_GET, [](AsyncWebServerRequest *request) // Serveur récupère les infos esp32
             {request->send(200, "text/plain", info_pan);});
  server.on("/app", HTTP_GET, [](AsyncWebServerRequest *request)   // Serveur récupère thermostat_update
             {request->send(200, "text/plain", thermostat_update);});
  server.begin();                            // Démarrage du serveur
/********************                               LOOP()                            ********************/
void loop()
  float tempIn;                              // Variables de comparaison des températures
  float tempPan;
  float tempOut;
  sensors.requestTemperatures();             // Récupération des températures
  tempPan = sensors.getTempC(panDS);         // Allocation des températures aux variables
  tempOut = sensors.getTempC(outDS);
  tempIn = sensors.getTempC(inDS);
  if(Tin!=tempIn)    {Tin = tempIn;}         // Actualisation si différentes après comparaison
  if(Tpan!=tempPan)  {Tpan = tempPan;}
  if(Tout!=tempOut)  {Tout = tempOut;}
  Serial.println(Tout);
  Serial.println(Tpan);
  Serial.println(Tin);
  info_pan = String(Tout)+"_"+String(Tpan)+"_"+String(Tin)+"_"+ETAT+"_"+String(HUM)+"_"+String(TH);
  Serial.println(info_pan);
  thermostat_update=?????????
  delay(5000);
Users browsing this forum: No registered users and 100 guests
