Can I write to an INPUT GPIO pin?
cspwcspw
Postby cspwcspw » Thu Sep 27, 2018 4:58 pm
In some touch-screen detection software I found this code:
    pinMode(_yp, INPUT);
    pinMode(_ym, INPUT);
    digitalWrite(_yp, LOW);
    digitalWrite(_ym, LOW);
Does it mean anything to write to a pin configured for INPUT?
Is it possible to make a pin OUTPUT while ensuring its initial value. For example, I want to change a pin to OUTPUT,
but I don't want any spurious spikes. So suppose I have
    pinMode(pin, INPUT_PULLUP);
    pinMode(pin, OUTPUT);
    // How can I avoid an unintended low or undefined value happening here?  Can I set the pin value before
    // I make it OUTPUT?
    digitalWrite(pin, HIGH);
Peter
urbanze
Re: Can I write to an INPUT GPIO pin?
Postby urbanze » Thu Sep 27, 2018 6:46 pm
In some boards, write in an input will active pull up or pull down.
ESP_Sprite
Postby ESP_Sprite » Fri Sep 28, 2018 1:57 am
Moved to the Arduino forum.
bobtidey
Postby bobtidey » Fri Sep 28, 2018 7:34 am
It is perfectly legitimate and quite normal to write data to a GPIO before setting its mode.
The value will be held locally in the GPIO data register but will have no effect if the mode is input. Setting the mode to output will then immediately reflect the state of the data on the pin.
So it is common to write the value before setting the mode to avoid a glitch. The value written would depend on whether a pull up or pull down is used to determine the state of the pin whilst it is still in the input mode.
cspwcspw
Postby cspwcspw » Fri Sep 28, 2018 10:14 am
@ESP_sprite. Hi - I'm not sure why my topic was moved to Arduino forum. Did I miss something about where this should have gone in the first place?
I'm specifically wanting to know what happens on the ESP32 where I am running this code ...
Peter
cspwcspw
Postby cspwcspw » Fri Sep 28, 2018 10:16 am
@bobtidey - thanks, we live and learn! Makes sense that it works like this.
Peter
ESP_Sprite
Postby ESP_Sprite » Fri Sep 28, 2018 10:59 am
cspwcspw wrote:@ESP_sprite. Hi - I'm not sure why my topic was moved to Arduino forum. Did I miss something about where this should have gone in the first place?
You're using digitalWrite, which is an Arduino-specific statement.
cspwcspw
Postby cspwcspw » Tue Oct 02, 2018 3:45 am
@ESP_sprite - thanks, was not aware that digitalWrite was Arduino specific.
Is there a preferred way to set individual pins high or low on the ESP32, other than the port-at-a-time w1ts / w1tc manipulation?
Peter
Users browsing this forum: Baidu [Spider] and 37 guests
