I am having some difficulties. I tried to update the AT firmware with the firmware from Espressif's resource page. I think the firmware was successfully updated. I tried to update many different ways and the same error occurs. I downloaded the esp32-at git repo and used make flash, I used the latest ESPFlashDownloadTool_v3.6.4 (using both the individual bins and factory bin), and I even used esptool.py, writing the factory.bin file and I cannot access the ESP32-WROOM module through UART (IO16 and IO17). However, I can send an AT command through a UART connection on an Arduino compatible board and I get this message in return:
AT
ERR CODE:0x01030000
ERROR
and because I have a loop listening to the RX bus, I get this if I reset the module:
ready
I don't know what is going on. I am getting frustrated. I can't get a simple OK from the command AT.
AT Firmware Error
Re: AT Firmware Error
Hi
Did you get any fix for this issue? I have the same problem using latest (1.1.3) AT firmware direct from the ESP site...
ready
AT
^J
ERR CODE:0x010b0000
busy p...
OK
AT+GMR
^J+GMR
ERR CODE:0x010b0000
busy p...
AT version:1.1.3.0(5a40576 - Nov 28 2018 12:50:55)
SDK version:v3.0.7
compile time:Dec 21 2018 09:04:56
Bin version:1.1.3(WROOM-32)
OK
any fixes gratefully received
Brian
ready
AT
^J
ERR CODE:0x010b0000
busy p...
OK
AT+GMR
^J+GMR
ERR CODE:0x010b0000
busy p...
SDK version:v3.0.7
OK
Brian
The AT error code is in https://github.com/espressif/esp32-at/b ... e/esp_at.h
`ERR CODE:0x01030000` is a little weird, it means not find "AT", will it be a hardware issue?
`ERR CODE:0x010b0000` means that the system is executing the previous AT command, cannot accept the next one for now.
typedef enum {
ESP_AT_SUB_NO_AT = 0x03, /*!< not found AT or at or At or aT */
ESP_AT_SUB_CMD_PROCESSING = 0x0B, /*!< previous command is processing */
} esp_at_error_code;
If there are more characters after '\r\n', it will response 'busy p...'. Please check it.
Users browsing this forum: markkuk and 82 guests
