ESP32 with MPU6050 via Arduino IDE
FrankenApps
Postby FrankenApps » Tue Aug 21, 2018 9:58 am
I am trying to get a MPU6050 working with ESP32. The following code works, with a minor adjustment (see comment in the code) with an Arduino UNO. I ran the I2CScanner and detected the MPU6050 with the Adress 0x68, which is the default one. The connections should be right:
VCC -> 3V3
GND -> GND
SDA -> 21
SCL -> 22
I get the error code "I2C write failed: 7" or "I2C write failed: 6", I am not sure, but I think error code 6 happend, because I2C was not at 400 kHz there..
This is the code:
Main.ino
#include <Wire.h>
#include "Kalman.h"
#define RESTRICT_PITCH
Kalman kalmanX;
Kalman kalmanY;
//Kalman
double accX, accY, accZ;
double gyroX, gyroY, gyroZ;
int16_t tempRaw;
double gyroXangle, gyroYangle;
double compAngleX, compAngleY;
double kalAngleX, kalAngleY;
uint32_t timer;
uint32_t timer2;
uint8_t i2cData[14];
  //  TWBR = ((F_CPU / 400000L) - 16) / 2; //I2C bei 400kHz     !!! This did not work because Wire library of esp32 is different !!!
  //Sort of hacky solution:
   Wire.begin(21,22,400000); // Pins 21 und 22 bei 400kHz       !!! So I changed it to that, the effect should be the same !!!
  i2cData[0] = 7; //Sample Rate ist 100Hz
  i2cData[1] = 0x00; // Kein FSYNC und setzte 260 Hz Acc filtering, 256 Hz Gyro filtering, 8 KHz sampling
  i2cData[2] = 0x00;
  i2cData[3] = 0x00;
  while (i2cWrite(0x19, i2cData, 4, false));
  while (i2cWrite(0x6B, 0x01, true));
  while (i2cRead(0x75, i2cData, 1));
  if (i2cData[0] != 0x68) {
    Serial.print(F("Sensor nicht erreichbar!"));
    while (1);
  delay(100); //sensor hochfahren
  while (i2cRead(0x3B, i2cData, 6));
  accX = (i2cData[0] << 8) | i2cData[1];
  accY = (i2cData[2] << 8) | i2cData[3];
  accZ = (i2cData[4] << 8) | i2cData[5];
#ifdef RESTRICT_PITCH
  double roll  = atan2(accY, accZ) * RAD_TO_DEG;
  double pitch = atan(-accX / sqrt(accY * accY + accZ * accZ)) * RAD_TO_DEG;
#else
  double roll  = atan(accY / sqrt(accX * accX + accZ * accZ)) * RAD_TO_DEG;
  double pitch = atan2(-accX, accZ) * RAD_TO_DEG;
#endif
  kalmanX.setAngle(roll); //Startwinkel
  kalmanY.setAngle(pitch);
  gyroXangle = roll;
  gyroYangle = pitch;
  compAngleX = roll;
  compAngleY = pitch;
  timer = micros();
void loop(){
  double dt = (double)(micros() - timer2) / 1000000;
  timer2 = micros();
  Serial.println(MPU6050());
double MPU6050() {
 //Update die Arrays
  while (i2cRead(0x3B, i2cData, 14));
  accX = ((i2cData[0] << 8) | i2cData[1]);
  accY = ((i2cData[2] << 8) | i2cData[3]);
  accZ = ((i2cData[4] << 8) | i2cData[5]);
  tempRaw = (i2cData[6] << 8) | i2cData[7];
  gyroX = (i2cData[8] << 8) | i2cData[9];
  gyroY = (i2cData[10] << 8) | i2cData[11];
  gyroZ = (i2cData[12] << 8) | i2cData[13];
  double dt = (double)(micros() - timer) / 1000000;
  timer = micros();
#else // Eq. 28 and 29
#endif
  double gyroXrate = gyroX / 131.0;
  double gyroYrate = gyroY / 131.0;
  if ((roll < -90 && kalAngleX > 90) || (roll > 90 && kalAngleX < -90)) {
    compAngleX = roll;
    kalAngleX = roll;
    gyroXangle = roll;
  } else
    kalAngleX = kalmanX.getAngle(roll, gyroXrate, dt);
  if (abs(kalAngleX) > 90)
    gyroYrate = -gyroYrate;
  kalAngleY = kalmanY.getAngle(pitch, gyroYrate, dt);
#else
  if ((pitch < -90 && kalAngleY > 90) || (pitch > 90 && kalAngleY < -90)) {
    compAngleY = pitch;
    kalAngleY = pitch;
    gyroYangle = pitch;
  } else
  if (abs(kalAngleY) > 90)
    gyroXrate = -gyroXrate;
#endif
  gyroXangle += gyroXrate * dt;
  gyroYangle += gyroYrate * dt;
  compAngleX = 0.93 * (compAngleX + gyroXrate * dt) + 0.07 * roll; // Calculate the angle using a Complimentary filter
  compAngleY = 0.93 * (compAngleY + gyroYrate * dt) + 0.07 * pitch;
 //resete Gyroskop nach zu großer Differenz
  if (gyroXangle < -180 || gyroXangle > 180)
    gyroXangle = kalAngleX;
  if (gyroYangle < -180 || gyroYangle > 180)
    gyroYangle = kalAngleY;
  return(kalAngleY);
I2C.ino
const uint8_t IMUAddress = 0x68;
const uint16_t I2C_TIMEOUT = 1000;
uint8_t i2cWrite(uint8_t registerAddress, uint8_t data, bool sendStop) {
  return i2cWrite(registerAddress, &data, 1, sendStop);
uint8_t i2cWrite(uint8_t registerAddress, uint8_t *data, uint8_t length, bool sendStop) {
  Wire.beginTransmission(IMUAddress);
  Wire.write(registerAddress);
  Wire.write(data, length);
  uint8_t rcode = Wire.endTransmission(sendStop);
  if (rcode) {
    Serial.print(F("i2cWrite failed: "));
    Serial.println(rcode);
  return rcode;
uint8_t i2cRead(uint8_t registerAddress, uint8_t *data, uint8_t nbytes) {
  uint32_t timeOutTimer;
  uint8_t rcode = Wire.endTransmission(false);
  if (rcode) {
    Serial.print(F("i2cRead failed: "));
    return rcode;
  Wire.requestFrom(IMUAddress, nbytes, (uint8_t)true);
  for (uint8_t i = 0; i < nbytes; i++) {
    if (Wire.available())
      data[i] = Wire.read();
    else {
      timeOutTimer = micros();
      while (((micros() - timeOutTimer) < I2C_TIMEOUT) && !Wire.available());
      else {
        Serial.println(F("i2cRead timeout"));
        return 5;
  return 0;
Any hint on what could have gone wrong would be really helpful. Thanks in advance :lol:
Deouss
Re: ESP32 with MPU6050 via Arduino IDE
Postby Deouss » Tue Aug 21, 2018 12:48 pm
Maybe talk to author of your library. This one https://github.com/mohamed-elsabagh/esp32-mpu6050 seem to work fine
FrankenApps
Postby FrankenApps » Wed Aug 22, 2018 9:08 am
Well I do not use a library apart from Kalman.h which definitly can not be the problem...
I got my MPU6050 working with I2CDevLib and the MPU6050 library by Jeff Rowberg with the following changes:
https://github.com/jrowberg/i2cdevlib/pull/367
Then because it still did not work I replaced
#ifndef __arm__
    #include <avr/pgmspace.h>
#else
with
#ifndef __arm__
    #include <pgmspace.h>
#else
in "MPU6050_6Axis_MotionApps20.h".
Then I made two little changes in the "MPU6050_DMP6" Example to get it working:
        Wire.begin();
        TWBR = 24; // 400kHz I2C clock (200kHz if CPU is 8MHz)
changed to
Wire.begin(21 , 22, 400000);
and
Serial.println(F("Enabling interrupt detection (Arduino external interrupt 0)..."));
attachInterrupt(0, dmpDataReady, RISING);
needs to be changed to
Serial.println(F("Enabling interrupt detection (ESP32 pin 32)..."));
pinMode(32, INPUT_PULLUP);
attachInterrupt(32, dmpDataReady, RISING);
so the INT Pin must be connected to the GPIO 32.
So I got it working, but if anybody could nevertheless tell me why my initial code is not working, I would be glad to hear about that...
xvinny
Postby xvinny » Thu Aug 23, 2018 1:45 pm
FrankenApps,
I ran into the same problem with MPU6050 and got a bug in the last version of i2c library in arduino-esp32 SDK.
In order to apply a workaround until the next official release, you should download (from github.com/arduino-esp32) and replace these four files:
- libraries\Wire\Wire.cpp
- libraries\Wire\Wire.h
- cores\esp32\esp32-hal-i2c.cpp
- cores\esp32\esp32-hal-i2c.h
You will ask: why is this happening? Is Espressif releasing a bugged SDK?
The answer is yes, unfortunately. :evil:
So TAKE CARE when updating ESP SDK (both Arduino or ESP-IDF).
___________________________________________________________________________________________________________________________
Tell me if you knows how to use the Programmer module of Windows Calc and I'm gonna say who you are.
FrankenApps
Postby FrankenApps » Sat Aug 25, 2018 10:46 am
Ok, thanks for that suggestion.
It will unfortunately only work, if ESP32 core isn't installed via Boardsmanager :lol:
mcca69
Postby mcca69 » Wed Nov 21, 2018 6:03 am
FrankenApps,
That worked, I just replaced the files in the Arduino folder for the ESP32 libraries.
Thank you
xvinny
Postby xvinny » Fri Feb 22, 2019 5:03 pm
FrankenApps,
Thank you
The new version of the SDK has the fix for this bug ;)
ddnn88
Postby ddnn88 » Sat Mar 02, 2019 10:12 pm
Here is an example using ESP32 + MPU9250 + Arduino IDE:
https://www.hackster.io/donowak/esp32-m ... ion-467dc1 .
MPU9250 is something different than MPU6050, but maybe you will find something useful for your project :)
Users browsing this forum: No registered users and 55 guests
