Hi All,
Anyone using PlatformIO? I welcome opinions, experience, Pros and cons for this platform.
[BEN]
Using PlatformIO?
- Vader_Mester
- Contact:
Using PlatformIO?
task_t coffeeTask()
while(atWork){
coffeeDrink(mug);
vTaskDelete(NULL);
Re: Using PlatformIO?
I tried and hated it. When I switched to CMake it is so much better and so simple you cannot compare the convenience and speed
I mean Visual Studio Code + CMake build environment for ESP32 freeRTOS
I have been using platform IO for several months now. I am still on the fence with using it as compared to VSC & CMake.
I have not had any issues with it at all, and I like the ability to create a new project using either the Arduino framework or IDF.
I'll keep using both for now. The only downside I have seen with Platform IO is that (last I checked) when using Arduino you have no way to setup menuconfig.
Last time I checked PlatformIO does not work with FreeRTOS.
Did you manage to run and compile IDF projects in full RTOS environment or just Arduino?
I had quite some issues with Arduino as well
What do you mean both ?
Arduino uses IDF and runs on top of RTOS )
IDF is written in FreeRTOS API. Arduino is just a framework for RTOS.
Check my setup guide posted here:
https://esp32.com/viewtopic.php?f=13&t=6383
It means you're able to use PlatformIO for either Arduino projects or ESP-IDF projects side-by-side in one single installation.Deouss wrote:What do you mean both ?
P.S.: I will have a look at your guide, it could happen that I find your way better than PIO, who knows!
