ESPHTTPD Library
l1519066
ESPHTTPD Library
Postby l1519066 » Wed Jul 11, 2018 4:14 am
I just managed to get the esphttpd freeRTOS example linked below running. However, it is quite overkill. I can't seem to figure out what the bare minimum code I need just to display a web page to user.
https://github.com/chmorgan/esphttpd-fr ... ser_main.c
 * "THE BEER-WARE LICENSE" (Revision 42):
 * Jeroen Domburg <jeroen@spritesmods.com> wrote this file. As long as you retain
 * this notice you can do whatever you want with this stuff. If we meet some day,
 * and you think this stuff is worth it, you can buy me a beer in return.
This is example code for the esphttpd library. It's a small-ish demo showing off
the server, including WiFi connection management capabilities, some IO etc.
#include <libesphttpd/esp.h>
#include "libesphttpd/httpd.h"
#include "io.h"
#include "libesphttpd/httpdespfs.h"
#include "cgi.h"
#include "libesphttpd/cgiwifi.h"
#include "libesphttpd/cgiflash.h"
#include "libesphttpd/auth.h"
#include "libesphttpd/espfs.h"
#include "libesphttpd/captdns.h"
#include "libesphttpd/webpages-espfs.h"
#include "libesphttpd/cgiwebsocket.h"
#include "libesphttpd/httpd-freertos.h"
#include "libesphttpd/route.h"
#include "cgi-test.h"
#include "esp_wifi.h"
#include "freertos/task.h"
#include "freertos/semphr.h"
#include "freertos/queue.h"
#ifdef ESP32
#include "esp_log.h"
#include "esp_event_loop.h"
#include "nvs_flash.h"
#include "tcpip_adapter.h"
#endif
#define TAG "user_main"
#define LISTEN_PORT     80u
#define MAX_CONNECTIONS 32u
static char connectionMemory[sizeof(RtosConnType) * MAX_CONNECTIONS];
static HttpdFreertosInstance httpdFreertosInstance;
//Function that tells the authentication system what users/passwords live on the system.
//This is disabled in the default build; if you want to try it, enable the authBasic line in
//the builtInUrls below.
int myPassFn(HttpdConnData *connData, int no, char *user, int userLen, char *pass, int passLen) {
	if (no==0) {
		strcpy(user, "admin");
		strcpy(pass, "s3cr3t");
		return 1;
//Add more users this way. Check against incrementing no for each user added.
//	} else if (no==1) {
//		strcpy(user, "user1");
//		strcpy(pass, "something");
//		return 1;
	return 0;
//Broadcast the uptime in seconds every second over connected websockets
static void websocketBcast(void *arg) {
	static int ctr=0;
	char buff[128];
	while(1) {
		ctr++;
		sprintf(buff, "Up for %d minutes %d seconds!\n", ctr/60, ctr%60);
		cgiWebsockBroadcast(&httpdFreertosInstance.httpdInstance,
		                    "/websocket/ws.cgi", buff, strlen(buff),
		                    WEBSOCK_FLAG_NONE);
		vTaskDelay(1000/portTICK_RATE_MS);
//On reception of a message, send "You sent: " plus whatever the other side sent
static void myWebsocketRecv(Websock *ws, char *data, int len, int flags) {
	int i;
	char buff[128];
	sprintf(buff, "You sent: ");
	for (i=0; i<len; i++) buff[i+10]=data[i];
	buff[i+10]=0;
	cgiWebsocketSend(&httpdFreertosInstance.httpdInstance,
	                 ws, buff, strlen(buff), WEBSOCK_FLAG_NONE);
//Websocket connected. Install reception handler and send welcome message.
static void myWebsocketConnect(Websock *ws) {
	ws->recvCb=myWebsocketRecv;
	                 ws, "Hi, Websocket!", 14, WEBSOCK_FLAG_NONE);
//On reception of a message, echo it back verbatim
void myEchoWebsocketRecv(Websock *ws, char *data, int len, int flags) {
	printf("EchoWs: echo, len=%d\n", len);
	                 ws, data, len, flags);
//Echo websocket connected. Install reception handler.
void myEchoWebsocketConnect(Websock *ws) {
	printf("EchoWs: connect\n");
	ws->recvCb=myEchoWebsocketRecv;
#define OTA_FLASH_SIZE_K 1024
#define OTA_TAGNAME "generic"
CgiUploadFlashDef uploadParams={
	.type=CGIFLASH_TYPE_FW,
	.fw1Pos=0x1000,
	.fw2Pos=((OTA_FLASH_SIZE_K*1024)/2)+0x1000,
	.fwSize=((OTA_FLASH_SIZE_K*1024)/2)-0x1000,
	.tagName=OTA_TAGNAME
This is the main url->function dispatching data struct.
In short, it's a struct with various URLs plus their handlers. The handlers can
be 'standard' CGI functions you wrote, or 'special' CGIs requiring an argument.
They can also be auth-functions. An asterisk will match any url starting with
everything before the asterisks; "*" matches everything. The list will be
handled top-down, so make sure to put more specific rules above the more
general ones. Authorization things (like authBasic) act as a 'barrier' and
should be placed above the URLs they protect.
HttpdBuiltInUrl builtInUrls[]={
	ROUTE_CGI_ARG("*", cgiRedirectApClientToHostname, "esp8266.nonet"),
	ROUTE_REDIRECT("/", "/index.tpl"),
	ROUTE_TPL("/led.tpl", tplLed),
	ROUTE_TPL("/index.tpl", tplCounter),
	ROUTE_CGI("/led.cgi", cgiLed),
	ROUTE_REDIRECT("/flash", "/flash/index.html"),
	ROUTE_REDIRECT("/flash/", "/flash/index.html"),
	ROUTE_CGI_ARG("/flash/next", cgiGetFirmwareNext, &uploadParams),
	ROUTE_CGI_ARG("/flash/upload", cgiUploadFirmware, &uploadParams),
	ROUTE_CGI("/flash/reboot", cgiRebootFirmware),
	//Routines to make the /wifi URL and everything beneath it work.
//Enable the line below to protect the WiFi configuration with an username/password combo.
//	{"/wifi/*", authBasic, myPassFn},
	ROUTE_REDIRECT("/wifi", "/wifi/wifi.tpl"),
	ROUTE_REDIRECT("/wifi/", "/wifi/wifi.tpl"),
	ROUTE_CGI("/wifi/wifiscan.cgi", cgiWiFiScan),
	ROUTE_TPL("/wifi/wifi.tpl", tplWlan),
	ROUTE_CGI("/wifi/connect.cgi", cgiWiFiConnect),
	ROUTE_CGI("/wifi/connstatus.cgi", cgiWiFiConnStatus),
	ROUTE_CGI("/wifi/setmode.cgi", cgiWiFiSetMode),
	ROUTE_REDIRECT("/websocket", "/websocket/index.html"),
	ROUTE_WS("/websocket/ws.cgi", myWebsocketConnect),
	ROUTE_WS("/websocket/echo.cgi", myEchoWebsocketConnect),
	ROUTE_REDIRECT("/test", "/test/index.html"),
	ROUTE_CGI("/test/test.cgi", cgiTestbed),
	ROUTE_FILESYSTEM(),
	ROUTE_END()
#ifdef ESP32
static EventGroupHandle_t wifi_ap_event_group;
static EventGroupHandle_t wifi_sta_event_group;
/* The event group allows multiple bits for each event,
   but we only care about one event - are we connected
   to the AP with an IP? */
const static int CONNECTED_BIT = BIT0;
static esp_err_t wifi_event_handler(void *ctx, system_event_t *event)
    switch(event->event_id) {
    case SYSTEM_EVENT_STA_START:
        esp_wifi_connect();
    case SYSTEM_EVENT_STA_GOT_IP:
        xEventGroupSetBits(wifi_sta_event_group, CONNECTED_BIT);
    case SYSTEM_EVENT_STA_CONNECTED:
    case SYSTEM_EVENT_STA_DISCONNECTED:
        /* This is a workaround as ESP32 WiFi libs don't currently
           auto-reassociate. */
        esp_wifi_connect();
        xEventGroupClearBits(wifi_sta_event_group, CONNECTED_BIT);
    case SYSTEM_EVENT_AP_START:
        tcpip_adapter_ip_info_t ap_ip_info;
        if (tcpip_adapter_get_ip_info(TCPIP_ADAPTER_IF_AP, &ap_ip_info) == 0) {
            ESP_LOGI(TAG, "~~~~~~~~~~~");
            ESP_LOGI(TAG, "IP:" IPSTR, IP2STR(&ap_ip_info.ip));
            ESP_LOGI(TAG, "MASK:" IPSTR, IP2STR(&ap_ip_info.netmask));
            ESP_LOGI(TAG, "GW:" IPSTR, IP2STR(&ap_ip_info.gw));
    case SYSTEM_EVENT_AP_STACONNECTED:
        ESP_LOGI(TAG, "station:" MACSTR" join,AID=%d\n",
                MAC2STR(event->event_info.sta_connected.mac),
                event->event_info.sta_connected.aid);
        xEventGroupSetBits(wifi_ap_event_group, CONNECTED_BIT);
    case SYSTEM_EVENT_AP_STADISCONNECTED:
        ESP_LOGI(TAG, "station:" MACSTR"leave,AID=%d\n",
                MAC2STR(event->event_info.sta_disconnected.mac),
                event->event_info.sta_disconnected.aid);
        xEventGroupClearBits(wifi_ap_event_group, CONNECTED_BIT);
    case SYSTEM_EVENT_SCAN_DONE:
        wifiScanDoneCb();
    default:
    return ESP_OK;
//Simple task to connect to an access point
void ICACHE_FLASH_ATTR init_wifi(bool modeAP) {
	nvs_flash_init();
	wifi_sta_event_group = xEventGroupCreate();
	wifi_ap_event_group = xEventGroupCreate();
	ESP_ERROR_CHECK( esp_event_loop_init(wifi_event_handler, NULL) );
        ESP_ERROR_CHECK( esp_wifi_set_storage(WIFI_STORAGE_RAM) );
	//Go to station mode
	esp_wifi_disconnect();
	if(modeAP) {
		ESP_ERROR_CHECK( esp_wifi_set_mode(WIFI_MODE_AP) );
		wifi_config_t ap_config;
		strcpy((char*)(&ap_config.ap.ssid), "ESP");
		ap_config.ap.ssid_len = 3;
		ap_config.ap.channel = 1;
		ap_config.ap.authmode = WIFI_AUTH_OPEN;
		ap_config.ap.ssid_hidden = 0;
		ap_config.ap.max_connection = 1;
		ap_config.ap.beacon_interval = 100;
		esp_wifi_set_config(WIFI_IF_AP, &ap_config);
	else {
		esp_wifi_set_mode(WIFI_MODE_STA);
		//Connect to the defined access point.
		wifi_config_t config;
		memset(&config, 0, sizeof(config));
		sprintf((char*)config.sta.ssid, "RouterSSID");			// @TODO: Changeme
		sprintf((char*)config.sta.password, "RouterPassword"); 	// @TODO: Changeme
		esp_wifi_set_config(WIFI_IF_STA, &config);
		esp_wifi_connect();
#endif
//Main routine. Initialize stdout, the I/O, filesystem and the webserver and we're done.
#if ESP32
void app_main(void) {
#else
void user_init(void) {
#endif
#ifndef ESP32
	uart_div_modify(0, UART_CLK_FREQ / 115200);
#endif
	ioInit();
// FIXME: Re-enable this when capdns is fixed for esp32
//	captdnsInit();
	espFsInit((void*)(webpages_espfs_start));
	tcpip_adapter_init();
	httpdFreertosInit(&httpdFreertosInstance,
	                  builtInUrls,
	                  LISTEN_PORT,
	                  connectionMemory,
	                  MAX_CONNECTIONS,
	                  HTTPD_FLAG_NONE);
	init_wifi(true); // Supply false for STA mode
	xTaskCreate(websocketBcast, "wsbcast", 3000, NULL, 3, NULL);
	printf("\nReady\n");
Does anyone have a very basic example of this library to literally just serve one .html file ?
Users browsing this forum: No registered users and 40 guests
