I'm having a problem where connecting some signals to GPIO 25 and 26 seems to cause my I2C to become unstable.
I saw some messages in the (not arduino) parts of the forum that you have to turn off DAC1 and DAC2 to use these GPIO for input. Does this have to be done under arduino as well? If so, how do you do it?
Right now I just use
pinMode(25, INPUT);
and read them with
digitalRead(25);
Do I need to do something to turn off DAC1 & 2 to use GPIO 25 and 26 as input?
Using GPIO 25, 26 as digital IN?
Re: Using GPIO 25, 26 as digital IN?
I am running into the same issue right now.
I tried to add: dac_output_disable(DAC_GPIO26_CHANNEL);
But same result.
Did you find a solution ? Thanks
But same result.
Make sure WiFi is off.
Users browsing this forum: No registered users and 57 guests
