WiFi disconnects every 110 seconds
jimparis
Postby jimparis » Sat Jun 30, 2018 7:42 pm
I'm having a problem where my ESP32 disconnects from the WiFi access point after 110 seconds. It always reconnects just fine a few seconds later. The typical sequence is: Scan for APs, connect, immediately send a SNTP and HTTP request, get responses within a few seconds, then wait. After 110 seconds it disconnects with WIFI_REASON_NOT_ASSOCED.
The router is a Tenda AC1900.
This is my esp32 output:
I (30) boot: ESP-IDF v3.1-beta1 2nd stage bootloader
I (30) boot: compile time 13:45:37
I (30) boot: Enabling RNG early entropy source...
I (31) boot: SPI Speed      : 40MHz
I (31) boot: SPI Mode       : DIO
I (32) boot: SPI Flash Size : 4MB
I (32) boot: Partition Table:
I (33) boot: ## Label            Usage          Type ST Offset   Length
I (34) boot:  0 nvs              WiFi data        01 02 00009000 00004000
I (35) boot:  1 otadata          OTA data         01 00 0000d000 00002000
I (35) boot:  2 phy_init         RF data          01 01 0000f000 00001000
I (36) boot:  3 factory          factory app      00 00 00010000 00100000
I (37) boot:  4 ota_0            OTA app          00 10 00110000 00100000
I (38) boot:  5 ota_1            OTA app          00 11 00210000 00100000
I (39) boot: End of partition table
I (40) boot: Defaulting to factory image
I (40) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x1d110 (119056) map
I (83) esp_image: segment 1: paddr=0x0002d138 vaddr=0x3ffb0000 size=0x02ed8 ( 11992) load
I (88) esp_image: segment 2: paddr=0x00030018 vaddr=0x400d0018 size=0x8a69c (566940) map
_stext at ??:?
I (287) esp_image: segment 3: paddr=0x000ba6bc vaddr=0x3ffb2ed8 size=0x00da8 (  3496) load
I (289) esp_image: segment 4: paddr=0x000bb46c vaddr=0x3ffb3c80 size=0x00000 (     0) load
I (289) esp_image: segment 5: paddr=0x000bb474 vaddr=0x40080000 size=0x00400 (  1024) load
_iram_start at /home/jim/git/clock/fw/esp-idf/components/freertos/xtensa_vectors.S:1685
I (290) esp_image: segment 6: paddr=0x000bb87c vaddr=0x40080400 size=0x11b90 ( 72592) load
I (321) esp_image: segment 7: paddr=0x000cd414 vaddr=0x400c0000 size=0x00000 (     0) load
I (321) esp_image: segment 8: paddr=0x000cd41c vaddr=0x50000000 size=0x00000 (     0) load
I (333) boot: Loaded app from partition at offset 0x10000
I (333) boot: Disabling RNG early entropy source...
I (333) cpu_start: Pro cpu up.
I (333) cpu_start: Starting app cpu, entry point is 0x400810d0
call_start_cpu1 at /home/jim/git/clock/fw/esp-idf/components/esp32/cpu_start.c:225
I (0) cpu_start: App cpu up.
I (335) heap_init: Initializing. RAM available for dynamic allocation:
D (335) heap_init: New heap initialised at 0x3ffae6e0
I (336) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
D (337) heap_init: New heap initialised at 0x3ffbb3f0
I (337) heap_init: At 3FFBB3F0 len 00024C10 (147 KiB): DRAM
I (338) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (339) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
D (341) heap_init: New heap initialised at 0x40091f90
I (341) heap_init: At 40091F90 len 0000E070 (56 KiB): IRAM
I (342) cpu_start: Pro cpu start user code
D (342) clk: waiting for 32k oscillator to start up
E (580) clk: RTC: Not found External 32 kHz XTAL. Switching to Internal 150 kHz RC chain
D (600) clk: RTC_SLOW_CLK calibration value: 3263658
D (154) intr_alloc: Connected src 46 to int 2 (cpu 0)
D (157) intr_alloc: Connected src 57 to int 3 (cpu 0)
D (158) stack_chk: Intialize random stack guard
D (160) intr_alloc: Connected src 24 to int 9 (cpu 0)
I (161) cpu_start: Starting scheduler on PRO CPU.
D (0) intr_alloc: Connected src 25 to int 2 (cpu 1)
D (165) heap_init: New heap initialised at 0x3ffe0440
D (165) heap_init: New heap initialised at 0x3ffe4350
D (165) intr_alloc: Connected src 16 to int 12 (cpu 0)
I (185) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
D (185) intr_alloc: Connected src 50 to int 13 (cpu 0)
I (195) wifi_manager: init
I (195) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (195) wifi: wifi driver task: 3ffc6774, prio:23, stack:4096, core=0
I (195) wifi: wifi firmware version: b65dd05
I (195) wifi: config NVS flash: enabled
I (195) wifi: config nano formating: disabled
I (205) wifi: Init dynamic tx buffer num: 32
I (205) wifi: Init data frame dynamic rx buffer num: 32
I (215) wifi: Init management frame dynamic rx buffer num: 32
I (215) wifi: Init static rx buffer size: 1600
I (215) wifi: Init static rx buffer num: 10
I (215) wifi: Init dynamic rx buffer num: 32
I (265) phy: phy_version: 3910, c0c45a3, May 21 2018, 18:07:06, 0, 0
I (265) wifi: mode : sta (b4:e6:2d:ac:76:11)
I (275) wifi_manager: Scanning for access points
I (2685) wifi_manager: Connecting to SSID 'BACONPALACE' with passphrase 'xxxxx'
I (3295) wifi: n:5 0, o:1 0, ap:255 255, sta:5 0, prof:1
I (3965) wifi: state: init -> auth (b0)
I (3965) wifi: state: auth -> assoc (0)
I (3975) wifi: state: assoc -> run (10)
I (4005) wifi: connected with BACONPALACE, channel 5
I (4005) wifi: pm start, type: 1
I (5065) event: sta ip: 10.0.103.186, mask: 255.255.0.0, gw: 10.0.1.1
I (5065) wifi_manager: got new IP: 10.0.103.186
I (5065) wifi_manager: Connected!
I (5075) serverconfig: Sending HTTP request to https://example.com/clock/config?mac=b4:e6:2d:ac:76:11
I (5305) timekeeper: Time jump: 1530375078.947486 sec.  It is now: Sat Jun 30 12:11:24 2018
I (8095) serverconfig: HTTP response OK
I (114425) wifi: state: run -> auth (7c0)
I (114425) wifi: pm stop, total sleep time: 102976934 us / 110417391 us
I (114425) wifi: n:5 0, o:5 0, ap:255 255, sta:5 0, prof:1
I (114425) wifi_manager: disconnected; reason 7
W (114425) wifi_manager: Lost wifi connection
I (114425) wifi: state: auth -> init (0)
I (114425) wifi: flush txq
I (114425) wifi: stop sw txq
I (114425) wifi: lmac stop hw txq
I (114425) main: Not connected
I (114425) timekeeper: stop
I (114425) wifi_manager: disconnected; reason 202
Here is a Wireshark capture from a PC running in monitor mode. Summary:
No.     Time           Source                Destination           Protocol Info
      1 0.000000       b4:e6:2d:ac:76:11     Broadcast             802.11   Probe Request, SN=1, FN=0, Flags=........, SSID=Broadcast
      2 0.120779       b4:e6:2d:ac:76:11     Broadcast             802.11   Probe Request, SN=2, FN=0, Flags=........, SSID=Broadcast
      3 0.242098       b4:e6:2d:ac:76:11     Broadcast             802.11   Probe Request, SN=3, FN=0, Flags=........, SSID=Broadcast
      4 0.366290       b4:e6:2d:ac:76:11     Broadcast             802.11   Probe Request, SN=4, FN=0, Flags=........, SSID=Broadcast
      5 0.369544       TendaTec_56:6f:51     b4:e6:2d:ac:76:11     802.11   Probe Response, SN=858, FN=0, Flags=........, BI=100, SSID=BACONPALACE
      6 0.489386       b4:e6:2d:ac:76:11     Broadcast             802.11   Probe Request, SN=5, FN=0, Flags=........, SSID=Broadcast
      7 0.609858       b4:e6:2d:ac:76:11     Broadcast             802.11   Probe Request, SN=6, FN=0, Flags=........, SSID=Broadcast
      8 3.090074       b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Authentication, SN=0, FN=0, Flags=....R...
      9 3.090387                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
     10 5.219629       b4:e6:2d:ac:76:11     Broadcast             802.11   Probe Request, SN=1, FN=0, Flags=........, SSID=Broadcast
     11 5.341413       b4:e6:2d:ac:76:11     Broadcast             802.11   Probe Request, SN=2, FN=0, Flags=........, SSID=Broadcast
     12 5.461445       b4:e6:2d:ac:76:11     Broadcast             802.11   Probe Request, SN=3, FN=0, Flags=........, SSID=Broadcast
     13 5.582687       b4:e6:2d:ac:76:11     Broadcast             802.11   Probe Request, SN=4, FN=0, Flags=........, SSID=Broadcast
     14 5.585918       TendaTec_56:6f:51     b4:e6:2d:ac:76:11     802.11   Probe Response, SN=931, FN=0, Flags=........, BI=100, SSID=BACONPALACE
     15 5.704977       b4:e6:2d:ac:76:11     Broadcast             802.11   Probe Request, SN=5, FN=0, Flags=........, SSID=Broadcast
     16 5.825243       b4:e6:2d:ac:76:11     Broadcast             802.11   Probe Request, SN=6, FN=0, Flags=........, SSID=Broadcast
     17 5.945424       b4:e6:2d:ac:76:11     Broadcast             802.11   Probe Request, SN=7, FN=0, Flags=........, SSID=Broadcast
     18 7.512687       b4:e6:2d:ac:76:11     Broadcast             802.11   Probe Request, SN=11, FN=0, Flags=........, SSID=BACONPALACE
     19 7.515939       TendaTec_56:6f:51     b4:e6:2d:ac:76:11     802.11   Probe Response, SN=952, FN=0, Flags=........, BI=100, SSID=BACONPALACE
     20 7.521981       TendaTec_56:6f:51     b4:e6:2d:ac:76:11     802.11   Probe Response, SN=952, FN=0, Flags=....R..., BI=100, SSID=BACONPALACE
     21 8.309146       b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Authentication, SN=0, FN=0, Flags=........
     22 8.309477                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
     23 8.310063       TendaTec_56:6f:51     b4:e6:2d:ac:76:11     802.11   Authentication, SN=961, FN=0, Flags=........
     24 8.312711       b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Association Request, SN=1, FN=0, Flags=........, SSID=BACONPALACE
     25 8.313027                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
     26 8.314773       TendaTec_56:6f:51     b4:e6:2d:ac:76:11     802.11   Association Response, SN=962, FN=0, Flags=........
     27 8.320739       TendaTec_56:6f:51     b4:e6:2d:ac:76:11     802.11   Action, SN=963, FN=0, Flags=........
     28 8.322581       TendaTec_56:6f:51     b4:e6:2d:ac:76:11     EAPOL    Key (Message 1 of 4)
     29 8.323009       b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Action, SN=2, FN=0, Flags=........
     30 8.323102                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
     31 8.323577       TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   802.11 Block Ack Req, Flags=........
     32 8.328583       b4:e6:2d:ac:76:11     TendaTec_56:6f:51     EAPOL    Key (Message 2 of 4)
     33 8.328912                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
     34 8.332055       TendaTec_56:6f:51     b4:e6:2d:ac:76:11     EAPOL    Key (Message 3 of 4)
     35 8.335037       b4:e6:2d:ac:76:11     TendaTec_56:6f:51     EAPOL    Key (Message 4 of 4)
     36 8.336969       b4:e6:2d:ac:76:11     TendaTec_56:6f:51     EAPOL    Key (Message 4 of 4)
     37 8.338404       b4:e6:2d:ac:76:11     TendaTec_56:6f:51     EAPOL    Key (Message 4 of 4)
     38 8.338702                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
     39 8.339105       b4:e6:2d:ac:76:11 (TA) TendaTec_56:6f:51 (RA) 802.11   Request-to-send, Flags=........
     40 8.339419                             b4:e6:2d:ac:76:11 (RA) 802.11   Clear-to-send, Flags=........
     41 8.340712       b4:e6:2d:ac:76:11     TendaTec_56:6f:51     EAPOL    Key (Message 4 of 4)
     42 8.341050                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
     43 8.348525       b4:e6:2d:ac:76:11     Broadcast             802.11   QoS Data, SN=0, FN=0, Flags=.p.....T
     44 8.348837                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
     45 8.349244       TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
     46 8.349448       TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
     47 8.349674       TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
     48 8.350239       TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
     49 8.351563       SuperMic_8b:5d:f4     b4:e6:2d:ac:76:11     802.11   QoS Data, SN=2, FN=0, Flags=.p..R.F.
     50 8.385990       b4:e6:2d:ac:76:11     Broadcast             802.11   Data, SN=965, FN=0, Flags=.p....F.
     51 8.402329       b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=5, FN=0, Flags=...P...T
     52 8.402387                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
     53 8.765256       b4:e6:2d:ac:76:11     Broadcast             802.11   QoS Data, SN=1, FN=0, Flags=.p.P...T
     54 8.765548                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
     55 8.766238                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
     56 8.795617       b4:e6:2d:ac:76:11     Broadcast             802.11   Data, SN=970, FN=0, Flags=.p....F.
     57 8.821324       b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=7, FN=0, Flags=...P...T
     58 8.821381                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
     59 9.410426       b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=8, FN=0, Flags=.......T
     60 9.410483                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
     61 9.410548       TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
     62 9.410814       TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
     63 9.421064       b4:e6:2d:ac:76:11     Broadcast             802.11   QoS Data, SN=2, FN=0, Flags=.p.....T
     64 9.421354                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
     65 9.421807       TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
     66 9.431007       b4:e6:2d:ac:76:11     Broadcast             802.11   QoS Data, SN=3, FN=0, Flags=.p.....T
     67 9.431320                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
     68 9.432710       b4:e6:2d:ac:76:11     Broadcast             802.11   QoS Data, SN=4, FN=0, Flags=.p.....T
     69 9.433047                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
     70 9.433103       TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
     71 9.437116       b4:e6:2d:ac:76:11     SuperMic_8b:5d:f4     802.11   QoS Data, SN=0, FN=0, Flags=.p.....T
     72 9.437418                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
     73 9.438828       b4:e6:2d:ac:76:11     SuperMic_8b:5d:f4     802.11   QoS Data, SN=1, FN=0, Flags=.p.....T
     74 9.439167                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
     75 9.439328       TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
     76 9.448565       b4:e6:2d:ac:76:11     SuperMic_8b:5d:f4     802.11   QoS Data, SN=2, FN=0, Flags=.p.....T
     77 9.448875                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
     78 9.453456       b4:e6:2d:ac:76:11     SuperMic_8b:5d:f4     802.11   QoS Data, SN=3, FN=0, Flags=.p.....T
     79 9.453764                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
     80 9.453967       TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
     81 9.454232       TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
     82 9.454458       TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
     83 9.454709       TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
     84 9.457681       TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
     85 9.458069       TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
     86 9.458708       TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
     87 9.459301       TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
     88 9.460251       TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
     89 9.460866       TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
     90 9.465583       b4:e6:2d:ac:76:11     SuperMic_8b:5d:f4     802.11   QoS Data, SN=4, FN=0, Flags=.p..R..T
     91 9.465896                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
     92 9.469119       b4:e6:2d:ac:76:11     SuperMic_8b:5d:f4     802.11   QoS Data, SN=4, FN=0, Flags=.p..R..T
     93 9.469440                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
     94 9.469940       b4:e6:2d:ac:76:11 (TA) TendaTec_56:6f:51 (RA) 802.11   Request-to-send, Flags=........
     95 9.470467       b4:e6:2d:ac:76:11 (TA) TendaTec_56:6f:51 (RA) 802.11   Request-to-send, Flags=........
     96 9.470783                             b4:e6:2d:ac:76:11 (RA) 802.11   Clear-to-send, Flags=........
     97 9.471748       b4:e6:2d:ac:76:11     SuperMic_8b:5d:f4     802.11   QoS Data, SN=4, FN=0, Flags=.p..R..T
     98 9.472065                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
     99 9.476793       b4:e6:2d:ac:76:11     SuperMic_8b:5d:f4     802.11   QoS Data, SN=5, FN=0, Flags=.p.....T
    100 9.477105                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
    101 9.512390       b4:e6:2d:ac:76:11     Broadcast             802.11   Data, SN=979, FN=0, Flags=.pm...F.
    102 9.513228       b4:e6:2d:ac:76:11     Broadcast             802.11   Data, SN=980, FN=0, Flags=.pm...F.
    103 9.514049       b4:e6:2d:ac:76:11     Broadcast             802.11   Data, SN=981, FN=0, Flags=.p....F.
    104 9.523177       b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=9, FN=0, Flags=...P...T
    105 9.523230                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
    106 9.616140       b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=10, FN=0, Flags=.......T
    107 9.616200                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
    108 9.616255       TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
    109 9.621819       b4:e6:2d:ac:76:11     SuperMic_8b:5d:f4     802.11   QoS Data, SN=6, FN=0, Flags=.p.....T
    110 9.622112                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
    111 9.623275       b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Action, SN=11, FN=0, Flags=........
    112 9.623978       b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Action, SN=11, FN=0, Flags=....R...
    113 9.624070                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
    114 9.624643       TendaTec_56:6f:51     b4:e6:2d:ac:76:11     802.11   Action, SN=983, FN=0, Flags=........
    115 9.645667       TendaTec_56:6f:51     b4:e6:2d:ac:76:11     802.11   Action, SN=984, FN=0, Flags=........
    116 9.648864       b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Action, SN=12, FN=0, Flags=........
    117 9.649329       b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Action, SN=12, FN=0, Flags=....R...
    118 9.649575       b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Action, SN=12, FN=0, Flags=....R...
    119 9.649645                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
    120 9.650249       TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   802.11 Block Ack Req, Flags=........
    121 9.702358       b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=13, FN=0, Flags=...P...T
    122 9.702408                             b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
    123 10.031675      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=14, FN=0, Flags=.......T
    124 10.031726                            b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
    125 10.082440      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=15, FN=0, Flags=...P...T
    126 10.082499                            b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
    127 10.331840      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=16, FN=0, Flags=.......T
    128 10.331902                            b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
    129 10.331964      TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
    130 10.335891      TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
    131 10.336208      TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
    132 10.337738      TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
    133 10.388091      TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
    134 10.392781      TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
    135 10.393129      TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
    136 10.409340      TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
    137 10.415154      TendaTec_56:6f:51 (TA) b4:e6:2d:ac:76:11 (RA) 802.11   Request-to-send, Flags=........
    138 10.466683      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=17, FN=0, Flags=...P...T
    139 10.466749                            b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
    140 28.462450      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=18, FN=0, Flags=....R..T
    141 28.463089      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=18, FN=0, Flags=....R..T
    142 28.463664      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=18, FN=0, Flags=....R..T
    143 28.464293      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=18, FN=0, Flags=....R..T
    144 28.464834      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=18, FN=0, Flags=....R..T
    145 28.465401      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=19, FN=0, Flags=.......T
    146 28.466245                            b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
    147 28.517364      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=20, FN=0, Flags=...PR..T
    148 28.518550      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=20, FN=0, Flags=...PR..T
    149 28.519100      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=20, FN=0, Flags=...PR..T
    150 28.519612      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=20, FN=0, Flags=...PR..T
    151 28.520131      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=20, FN=0, Flags=...PR..T
    152 28.520628      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=20, FN=0, Flags=...PR..T
    153 28.522333      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=21, FN=0, Flags=...PR..T
    154 28.522492      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=21, FN=0, Flags=...PR..T
    155 28.523021      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=21, FN=0, Flags=...PR..T
    156 28.523534      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=21, FN=0, Flags=...PR..T
    157 28.524050      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=21, FN=0, Flags=...PR..T
    158 28.524565      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=21, FN=0, Flags=...PR..T
    159 28.525075      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=21, FN=0, Flags=...PR..T
    160 28.525508      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=22, FN=0, Flags=...P...T
    161 28.525708      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=22, FN=0, Flags=...PR..T
    162 28.525870      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=22, FN=0, Flags=...PR..T
    163 28.526035      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=22, FN=0, Flags=...PR..T
    164 28.526198      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=22, FN=0, Flags=...PR..T
    165 28.527068      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=22, FN=0, Flags=...PR..T
    166 28.527581      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=22, FN=0, Flags=...PR..T
    167 28.528320      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=22, FN=0, Flags=...PR..T
    168 28.528831      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=22, FN=0, Flags=...PR..T
    169 28.533253      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=23, FN=0, Flags=...PR..T
    170 28.535053      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=24, FN=0, Flags=...PR..T
    171 28.535562      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=24, FN=0, Flags=...PR..T
    172 28.536085      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=24, FN=0, Flags=...PR..T
    173 28.536597      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=24, FN=0, Flags=...PR..T
    174 28.537111      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=24, FN=0, Flags=...PR..T
    175 28.538980      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=25, FN=0, Flags=...PR..T
    176 28.539515      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=25, FN=0, Flags=...PR..T
    177 28.540037      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=25, FN=0, Flags=...PR..T
    178 28.540583      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=25, FN=0, Flags=...PR..T
    179 28.541076      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=25, FN=0, Flags=...PR..T
    180 28.542882      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=26, FN=0, Flags=...PR..T
    181 28.543394      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=26, FN=0, Flags=...PR..T
    182 28.543889      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=26, FN=0, Flags=...PR..T
    183 28.544407      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=26, FN=0, Flags=...PR..T
    184 28.545080      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=26, FN=0, Flags=...PR..T
    185 28.546999      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=27, FN=0, Flags=...PR..T
    186 28.547833      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=27, FN=0, Flags=...PR..T
    187 28.548392      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=27, FN=0, Flags=...PR..T
    188 28.549025      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=27, FN=0, Flags=...PR..T
    189 28.549933      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=27, FN=0, Flags=...PR..T
    190 28.551610      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=28, FN=0, Flags=...PR..T
    191 28.553327      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=28, FN=0, Flags=...PR..T
    192 28.553839      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=28, FN=0, Flags=...PR..T
    193 28.554351      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=28, FN=0, Flags=...PR..T
    194 28.554885      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=28, FN=0, Flags=...PR..T
    195 28.555400      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=28, FN=0, Flags=...PR..T
    196 28.557150      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=29, FN=0, Flags=...PR..T
    197 28.557736      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=29, FN=0, Flags=...PR..T
    198 28.558271      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=29, FN=0, Flags=...PR..T
    199 28.558807      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=29, FN=0, Flags=...PR..T
    200 28.559324      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=29, FN=0, Flags=...PR..T
    201 28.561123      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=30, FN=0, Flags=...PR..T
    202 28.561666      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=30, FN=0, Flags=...PR..T
    203 28.562189      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=30, FN=0, Flags=...PR..T
    204 28.562705      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=30, FN=0, Flags=...PR..T
    205 28.563218      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=30, FN=0, Flags=...PR..T
    206 28.563951      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=31, FN=0, Flags=...PR..T
    207 28.564974      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=31, FN=0, Flags=...PR..T
    208 28.565482      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=31, FN=0, Flags=...PR..T
    209 28.566029      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=31, FN=0, Flags=...PR..T
    210 28.566544      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=31, FN=0, Flags=...PR..T
    211 28.567106      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=31, FN=0, Flags=...PR..T
    212 28.568417      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=32, FN=0, Flags=...PR..T
    213 28.568940      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=32, FN=0, Flags=...PR..T
    214 28.569436      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=32, FN=0, Flags=...PR..T
    215 28.570068      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=32, FN=0, Flags=...PR..T
    216 28.570582      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=32, FN=0, Flags=...PR..T
    217 28.571120      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=32, FN=0, Flags=...PR..T
    218 28.572858      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=33, FN=0, Flags=...PR..T
    219 28.573377      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=33, FN=0, Flags=...PR..T
    220 28.573882      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=33, FN=0, Flags=...PR..T
    221 28.574423      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=33, FN=0, Flags=...PR..T
    222 28.575036      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=33, FN=0, Flags=...PR..T
    223 28.575855      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=34, FN=0, Flags=...P...T
    224 28.576047      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=34, FN=0, Flags=...PR..T
    225 28.577384      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=34, FN=0, Flags=...PR..T
    226 28.577897      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=34, FN=0, Flags=...PR..T
    227 28.578438      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=34, FN=0, Flags=...PR..T
    228 28.578758                            b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
    229 39.720387      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=35, FN=0, Flags=.......T
    230 39.720460                            b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
    231 39.722308      TendaTec_56:6f:51     b4:e6:2d:ac:76:11     802.11   QoS Null function (No data), SN=1352, FN=0, Flags=......F.
    232 39.772553      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=36, FN=0, Flags=...PR..T
    233 39.772618                            b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
    234 58.564985      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=37, FN=0, Flags=.......T
    235 58.565045                            b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
    236 58.615670      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=38, FN=0, Flags=...P...T
    237 58.615725                            b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
    238 78.632663      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=39, FN=0, Flags=.......T
    239 78.632761                            b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
    240 78.684585                            b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
    241 98.702148      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=41, FN=0, Flags=.......T
    242 98.702222                            b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
    243 98.753389      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=42, FN=0, Flags=...PR..T
    244 98.753783      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=42, FN=0, Flags=...PR..T
    245 98.754685      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=42, FN=0, Flags=...PR..T
    246 98.755216      b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=42, FN=0, Flags=...PR..T
    247 98.755536                            b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
    248 118.775486     b4:e6:2d:ac:76:11     TendaTec_56:6f:51     802.11   Null function (No data), SN=43, FN=0, Flags=.......T
    249 118.775562                           b4:e6:2d:ac:76:11 (RA) 802.11   Acknowledgement, Flags=........
    250 118.776007     TendaTec_56:6f:51     b4:e6:2d:ac:76:11     802.11   Deauthentication, SN=2360, FN=0, Flags=........
Full PCAP file and logs available here: https://psy.jim.sh/www/tmp/esp32/
Any thoughts? Does anything look unusual in that capture? I know very little about 802.11 but that burst of "Null function" with repeated SNs seems suspicious.
Jim
jimparis
Re: WiFi disconnects every 110 seconds
Postby jimparis » Tue Jul 03, 2018 3:17 pm
Sending continuous ping requests (every 1s) prevents the station from being disconnected, but I would prefer not to have to do this.
Explicitly calling esp_wifi_set_ps(WIFI_PS_NONE), rather than leaving at the default WIFI_PS_MIN_MODEM, does not help.
Any suggestions?
Users browsing this forum: No registered users and 117 guests
