Caching issues with mmap'ed flash
jens.alfke
Postby jens.alfke » Thu Jun 28, 2018 4:17 pm
I'm calling esp_partition_mmap() to memory-map a flash partition, and then esp_partition_erase_range() and esp_partition_write() to write to it. Most of the time (95%?) this works fine, but intermittently I see errors where, after a write, part of the mapped memory is still filled with FF instead of the data I wrote.
I thought this might be a race condition with the flash controller (maybe the write takes longer than it indicates and sometimes it hasn't finished by the time the read occurs) so I added a 100ms delay after the write; that seems to help somewhat, but it's not a complete fix.
My only other hypothesis is that this is due to CPU cache coherency, but the spi_flash code looks like it's careful to disable/enable caches. I'm not familiar with the ESP32's cache system, but I assume it's doing the equivalent of a memory-barrier.
Any ideas?
Here's some rough code showing the kind of thing I do:
void *mapped;
esp_partition_mmap(partition, 0, partition_size, SPI_FLASH_MMAP_DATA, &mapped, &handle);
esp_partition_erase_range(partition, 0, 4096);
esp_partition_write(partition, 0, data, dataLength);
assert(memcmp(data, mapped, dataLength) == 0);    // sometimes fails
WiFive
Re: Caching issues with mmap'ed flash
Postby WiFive » Thu Jun 28, 2018 8:20 pm
It might be due to stale cache after erase if the cache is not automatically flushed.
jens.alfke
Postby jens.alfke » Thu Jun 28, 2018 10:00 pm
Yeah, that's what I'm thinking too; as I wrote above:
However I have no idea what additional cache might be at fault, nor how to flush it.
WiFive
Postby WiFive » Thu Jun 28, 2018 10:25 pm
Well spi_flash_write and spi_flash_erase will call spi_flash_mark_modified_region but it does not actually flush the cache until spi_flash_ensure_unmodified_region is called. So I don't know if there is a rule that you are supposed to unmap and remap memory if you are going to write/erase it.
jens.alfke
Postby jens.alfke » Thu Jun 28, 2018 10:36 pm
Looking through the spi_flash sources I found calls to a Cache_Flush() function; this looked promising, so I added
Cache_Flush(0); Cache_Flush(1);
to my code just after calling esp_partition_write(). That appears to have fixed the problem.
WiFive
Postby WiFive » Thu Jun 28, 2018 10:46 pm
I believe those should only be called inside flash guarded section.
jens.alfke
Postby jens.alfke » Tue Jul 03, 2018 11:31 pm
Users browsing this forum: alicia.huang, axellin, Google [Bot] and 146 guests
