what will cause reboot issue
alvin_xie
Postby alvin_xie » Thu Jun 28, 2018 8:56 am
I power off the ESP32 for 5 sec. and then power on it.
But the ESP32 will always reboot.
here is the log:
rst:0x10 (RTCWDT_RTC_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
cmd len -1
ets_main.c 371
ets Jun  8 2016 00:22:57
cmd len -1
ets_main.c 371
cmd len -1
ets_main.c 371
load:0x3fff0018,len:4
load:0x3fff001c,len:5772
load:0x40078000,len:0
load:0x40078000,len:13804
csum err:0xe6!=0xc8
ets_main.c 371
cmd len -1
ets_main.c 371
what will cause this issue?
chegewara
Re: what will cause reboot issue
Postby chegewara » Thu Jun 28, 2018 10:39 am
Maybe this?
csum err:0xe6!=0xc8
WiFive
Postby WiFive » Thu Jun 28, 2018 2:06 pm
0x33 means you have gpio12 pulled up and should have 1.8v flash (wrover or d2wd), do you?
Pibbotley
Postby Pibbotley » Fri Jun 29, 2018 4:02 pm
As above, disconnect pin 12 and try again. I avoid pin 12 if I can.
ESP_igrr
Postby ESP_igrr » Sat Jun 30, 2018 1:39 pm
Alternatively, use espefuse.py to set flash voltage to 3.3V. Then the state of GPIO12 will not matter.
Pibbotley
Postby Pibbotley » Sat Jun 30, 2018 4:52 pm
I've learned something, thanks
alvin_xie
Postby alvin_xie » Mon Jul 16, 2018 2:02 am
ESP_igrr wrote:Alternatively, use espefuse.py to set flash voltage to 3.3V. Then the state of GPIO12 will not matter.
how to do this?
ESP_igrr
Postby ESP_igrr » Wed Jul 18, 2018 9:54 am
Users browsing this forum: mjgciltd and 63 guests
