How bout dat RSSI
fly135
How bout dat RSSI
Postby fly135 » Thu May 03, 2018 1:05 am
Just curious how people have experienced connectivity problems and associated RSSI readings.
I'm been wanting to diagnose error conditions under congested wifi and found that moving the router far enough away and reducing signal strength can generate lots of delayed transmissions and slow or fails data transfers. Good enough to check my error returns and make decisions about timeouts.
At the current location I am reading -85 on the RSSI for that AP and identical posts to the cloud of small data varies between 1 - 20 sec to complete. OTA updates fail from 50K to 1.2M before giving up the ghost. Uploads of sound files don't complete. MQTT disconnects and reconnects. Before I move my AP I was reading -56 and everything was snappy. Plan to move the AP around and see where the reliability starts to fail.
Be cool if other people checked their RSSI and related performance experience. This is all you need to do....
wifi_ap_record_t wifidata;
if (esp_wifi_sta_get_ap_info(&wifidata)==0)
  printf("rssi:%d\r\n", wifidata.rssi);
fly135
Re: How bout dat RSSI
Postby fly135 » Thu May 03, 2018 3:53 pm
Moved my wifi router to another room. With an RSSI of -75 I'm getting good data transfers.
John A
Pibbotley
Postby Pibbotley » Thu May 03, 2018 6:00 pm
I buy second hand routers for peanuts and configure them as bridges to the dedicated router. My ESP32s then connect to whichever has the strongest signal.
woofy!
Postby woofy! » Fri May 04, 2018 8:54 am
For my oil tank monitor I see an RSSI of -75 to -85 and a transfer time of 1.5 to 2 seconds. Transfer time is from wake up through sensor data collection, sending the data to my MQTT server and back to deep sleep. This is in a fairly clean WIFI environment.
There's a screen shot in my post here:
viewtopic.php?f=2&t=5018&p=23295#p23283
fly135
Postby fly135 » Fri May 04, 2018 4:13 pm
I'm in a clean wifi environment and can xfer small amounts at ~-85. But larger amounts of audio or OTA tend to fail. I can upload my audio files and do OTA around ~-80. But in the office where wifi is congested OTA updates freq fail at -76.
@pibbotley, I'm actually moving the wifi router further away to simulate poor reception conditions and the associated errors.
John A
Users browsing this forum: Baidu [Spider] and 69 guests
