How to get two HS LEDC channels fading in two "parallel" Tasks?
kb3523
Postby kb3523 » Thu Mar 08, 2018 11:54 pm
Dear ESP Communitiy,
I can't get this working - what am I missing? Also tried using two different Timers for this. Both tasks are running as far as I can tell, but the second output stays shut. I tried at first fading led1 and as it finishes fading led2 without using tasks with the same configuration and that worked.
#include <stdio.h>
#include "freertos/task.h"
#include "driver/ledc.h"
#include "esp_err.h"
#include "esp_log.h"
#define LEDC_FAST_FADE_TIME (1000)
#define LEDC_SLOW_FADE_TIME (1000)
#define LEDC_DUTY         (4000)
#define LED_GREEN_GPIO (GPIO_NUM_22)
#define LED_RED_GPIO (GPIO_NUM_21)
ledc_channel_config_t green_led_conf;
ledc_channel_config_t red_led_conf;
static const char *TAG = "#LOG:";
static void blink_red (void)
	ledc_set_fade_with_time(red_led_conf.speed_mode,red_led_conf.channel, LEDC_DUTY, LEDC_SLOW_FADE_TIME);
	ledc_fade_start(red_led_conf.speed_mode, red_led_conf.channel, LEDC_FADE_NO_WAIT);
	vTaskDelay(LEDC_SLOW_FADE_TIME / portTICK_PERIOD_MS);
	ledc_set_fade_with_time(red_led_conf.speed_mode, red_led_conf.channel, 0, LEDC_SLOW_FADE_TIME);
static void blink_green (void)
	ledc_set_fade_with_time(green_led_conf.speed_mode, green_led_conf.channel, LEDC_DUTY, LEDC_FAST_FADE_TIME);
	ledc_fade_start(green_led_conf.speed_mode, green_led_conf.channel, LEDC_FADE_NO_WAIT);
	vTaskDelay(LEDC_FAST_FADE_TIME / portTICK_PERIOD_MS);
	ledc_set_fade_with_time(green_led_conf.speed_mode, green_led_conf.channel, 0, LEDC_FAST_FADE_TIME);
static void blink_red_task (void *pvParameter)
	while (1)
		ESP_LOGI(TAG, "RED LED IS BLINKING.. TASK RUNNING");
		blink_red();
static void blink_green_fast_task (void *pvParameter)
	while (1)
		ESP_LOGI(TAG, "GREEN LED IS BLINKING FAST.. TASK RUNNING");
		blink_green();
static void init_ledc (void)
    ledc_timer_config_t ledc_timer = {
        .bit_num = LEDC_TIMER_13_BIT, 		  // resolution
        .freq_hz = 5000,                      // frequency of PWM signal
        .speed_mode = LEDC_HIGH_SPEED_MODE,           // timer mode
        .timer_num = LEDC_TIMER_0            // timer index
    // Set configuration of timer0 for high speed channels
    ledc_timer_config(&ledc_timer);
    // Prepare channel configs
    ledc_channel_config_t green_led_conf =
			.channel    = LEDC_CHANNEL_0,
			.duty       = 0,
			.gpio_num   = (GPIO_NUM_22),//LED_GREEN_GPIO,
			.timer_sel  = LEDC_TIMER_0,
			.intr_type = LEDC_INTR_DISABLE
    ledc_channel_config_t red_led_conf =
			.channel    = LEDC_CHANNEL_1,
			.duty       = 0,
			.gpio_num   = (GPIO_NUM_21), //LED_RED_GPIO,
    // Set LED Controller with previously prepared configuration
	ledc_channel_config(&red_led_conf);
	ledc_channel_config(&green_led_conf);
    // Initialize fade service.
	ledc_fade_func_install(0);
void app_main()
	init_ledc();
	blink_red();
	blink_green();
	xTaskCreate(&blink_red_task, "blink_red_task", 2048, NULL, 5, NULL);
	vTaskDelay(100);
	xTaskCreate(&blink_green_fast_task, "blink_green_fast_task", 2048, NULL, 5, NULL);
If
Any suggestions are welcome ;) Thank you!
kb3523
Re: How to get two HS LEDC channels fading in two "parallel" Tasks?
Postby kb3523 » Fri Mar 09, 2018 10:38 am
I forget to mention, that with this code was successfully fading both outputs:
#include <stdio.h>
#define LEDC_HS_CH0_GPIO       (GPIO_NUM_21)
#define LEDC_HS_CH1_GPIO       (GPIO_NUM_22)
#define LEDC_TEST_FADE_TIME    (1000)
#define LEDC_FAST_FADE_TIME (250)
#define LEDC_SLOW_FADE_TIME (500)
void app_main()
        .bit_num = LEDC_TIMER_13_BIT, // resolution of PWM duty Later: .duty_resolution =
    ledc_channel_config_t ledc_channel[2] = {
            .duty       = 0,
            .gpio_num   = LEDC_HS_CH0_GPIO,
            .duty       = 0,
            .gpio_num   = LEDC_HS_CH1_GPIO,
    ledc_channel_config(&ledc_channel[0]);
    ledc_channel_config(&ledc_channel[1]);
    while (1) {
		printf("LEDC 1 fade up to duty = %d\n", LEDC_DUTY);
		ledc_set_fade_with_time(ledc_channel[1].speed_mode, ledc_channel[1].channel, LEDC_DUTY, LEDC_TEST_FADE_TIME);
		ledc_fade_start(ledc_channel[1].speed_mode, ledc_channel[1].channel, LEDC_FADE_NO_WAIT);
		vTaskDelay(LEDC_TEST_FADE_TIME / portTICK_PERIOD_MS);
		printf("LEDC 1 fade down to duty = 0\n");
		ledc_set_fade_with_time(ledc_channel[1].speed_mode, ledc_channel[1].channel, 0, LEDC_TEST_FADE_TIME);
		printf("LEDC 2 fade up to duty = %d\n", LEDC_DUTY);
		ledc_set_fade_with_time(ledc_channel[0].speed_mode, ledc_channel[0].channel, LEDC_DUTY, LEDC_SLOW_FADE_TIME);
		ledc_fade_start(ledc_channel[0].speed_mode,	ledc_channel[0].channel, LEDC_FADE_NO_WAIT);
		ledc_set_fade_with_time(ledc_channel[0].speed_mode, ledc_channel[0].channel, 0, LEDC_SLOW_FADE_TIME);
		ledc_fade_start(ledc_channel[0].speed_mode,ledc_channel[0].channel, LEDC_FADE_NO_WAIT);
		printf("LEDC 1 set DUTY to %d\n", LEDC_DUTY);
		ledc_set_duty(ledc_channel[0].speed_mode, ledc_channel[0].channel, LEDC_DUTY);
		ledc_update_duty(ledc_channel[0].speed_mode, ledc_channel[0].channel);
		printf("LEDC 1 set duty = 0\n");
		ledc_set_duty(ledc_channel[0].speed_mode, ledc_channel[0].channel, 0);
Maybe for one of you it is obvious why this example works and mine posted above don't, but I cant see any real difference. I'm also quiet new to RTOS and ESP-IDF. Thank you for reading this through! :)
kb3523
Postby kb3523 » Fri Mar 09, 2018 9:27 pm
Sorry :)
I was too noob to initialize an array of structs correctly..
False:
ledc_channel_config_t ledc_channel[2];
            .duty       = 0,
Right:
ledc_channel[0].channel   = LEDC_CHANNEL_0;
 ledc_channel[0].duty= 0;
Users browsing this forum: Bing [Bot] and 75 guests
