Using SMP with white list.
slivingston
Postby slivingston » Tue Feb 27, 2018 1:40 pm
I am trying to use the white list feature and either I am doing something wrong or I misunderstand the purpose of the advertising filter. I would like to limit scans and connections to previously bonded devices. So I am adding the bda of each bonded device to the white list using the following code:
    int dev_num = esp_ble_get_bond_device_num();
    esp_ble_bond_dev_t *dev_list = (esp_ble_bond_dev_t *)malloc(sizeof(esp_ble_bond_dev_t) * dev_num);
    esp_ble_get_bond_device_list(&dev_num, dev_list);
    for (int i = 0; i < dev_num; i++) {
            esp_err_t result = esp_ble_gap_update_whitelist(true, dev_list[i].bd_addr);
            if (result != ESP_OK) {
                ESP_LOGI(TAG, "Error updating white list - %d.", result);
      free(dev_list);
Then I set the advertising filter as follows:
static esp_ble_adv_params_t master_adv_params = {
    .adv_int_min        = 0x0020,
    .adv_int_max        = 0x0040,
    .adv_type           = ADV_TYPE_IND,
    .own_addr_type      = BLE_ADDR_TYPE_PUBLIC,
    .channel_map        = ADV_CHNL_ALL,
    .adv_filter_policy 	= ADV_FILTER_ALLOW_SCAN_WLST_CON_WLST;,
esp_ble_gap_start_advertising(&master_adv_params);
The behavior I am seeing is not what I would expect. If I use a legacy device that does not use privacy mode, the filtering seems to work and I can reconnect with a previously bonded device. However, if I am using a more recent version of Android with privacy mode enabled, the master device cannot see my device in scanning using nRF connect nor can it reconnect.
If, however, I set the filter to ADV_FILTER_ALLOW_SCAN_WLST_CON_ANY, I can connect with the Android with privacy mode.
What I can see is that the Android is using a consistent BDA even when in privacy mode because it has previously bonded with my device. Nevertheless, it does not see my device and cannot connect. Am I using the wrong bda for setting up the whitelist? I have tried to use a static address using the pid_key, but I ran up against a different problem expressed here viewtopic.php?f=14&t=4790.
Anyone else have success using white listing and bonded connections?
Users browsing this forum: No registered users and 71 guests
