Hello there!
I stumbled across chapter 13.3.4 "Baud Rate Detection" in the ESP32's technical reference and tried to implement this feature in one of my projects.
Although i did find a correspondig constant UART_AUTOBAUD_EN, i do not understand how to enable the detection. I also could not find any example.
Has somebody done this? Or is there an example and i just didn't find it?
Thanks in advance
Koschi
Is there an UART auto baud rate example?
Re: Is there an UART auto baud rate example?
So you have to calculate and set the baud yourself based on those values, it is not really "auto".UART_LOWPULSE_MIN_CNT stores minimum low-pulse width, UART_HIGHPULSE_MIN_CNT stores
minimum high-pulse width. By reading these two registers, software can calculate the baud rate of the
transmitter.
This is not how i interpreted this passage. I thought it was more like a "if you have auto baudrate detection and want to know where you're at, you have to calculatue it yourself". But it would work without that.
Anyways, i looked into directly writing to registers to do this, and it doesn't seem to work that easily. I'll first look into other ways to maybe get the result i need.
As it turns out a deviation from the target baudrate of about +/- 5% is not a problem. So i might try using this to "guess" the baudrate. Hoping it will not deviate too much.
Thanks anyways! Maybe i'll come back to this thread.
Users browsing this forum: No registered users and 90 guests
