ESP32CAM Arduino program with Guru Meditation Error:
paynterf
Postby paynterf » Wed Feb 19, 2025 11:59 pm
I have a very simple Arduino program to repeatedly (every 3 seconds) capture an image and convert it to BMP. When I run it, it crashes after the first iteration with a "Guru Meditation Error:" Here's the program:
// Visual Micro is in vMicro>General>Tutorial Mode
    Created:	1/30/2025 8:59:52 PM
    Author:     FRANK_XPS_9530\Frank
    This program captures a JPEG image from the camera and writes it out to the SD card
    In addition it converts the JPEG image to BMP888 format (3x the size + header) and
    writes it out to the SD card as well.
/*02/19/25 This branch modifies the program to make continuous image captures
  followed by max intensity spot search.  This will be used to find the extents
  of the image area
#include "esp_camera.h"
#include "Arduino.h"
#include "FS.h"                // SD Card ESP32
#include "SD_MMC.h"            // SD Card ESP32
#include "soc/soc.h"           // Disable brownout problems
#include "soc/rtc_cntl_reg.h"  // Disable brownout problems
#include "driver/rtc_io.h"
#include <EEPROM.h>            // read and write from flash memory
#include <elapsedMillis.h>
// define the number of bytes you want to access
#define EEPROM_SIZE 1
// Pin definition for CAMERA_MODEL_AI_THINKER
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
int pictureNumber = 0;
camera_fb_t* fb = NULL;
elapsedMillis MsSinceStart;
void setup()
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0); //disable brownout detector
  Serial.println("Starting Setup()");
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  if (psramFound()) {
    config.frame_size = FRAMESIZE_128X128; // FRAMESIZE_ + QVGA|CIF|VGA|SVGA|XGA|SXGA|UXGA
    config.jpeg_quality = 10;
    config.fb_count = 2;
  else {
    config.frame_size = FRAMESIZE_SVGA;
    config.jpeg_quality = 12;
    config.fb_count = 1;
  // Init Camera
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
  MsSinceStart = 0;
void loop()
  Serial.printf("%lu: Top of loop\n", (unsigned long)MsSinceStart);
  // Take Picture with Camera
  fb = esp_camera_fb_get();
  delay(500);//This is key to avoid an issue with the image being very dark and green. If needed adjust total delay time.
  Serial.printf("Image acquired: fb = %x fb_len = %d\n", fb, fb->len);
  //02/01/25 per https://www.esp32.com/viewtopic.php?t=17479 can convert JPG to BMP
  uint8_t* bmp_buf = NULL; //pointer to buffer of uint8_t objects
  size_t bmp_buf_len = 0;
  Serial.printf("%lu: Just before BMP conversion with fb = %p, bmp_buf = %p, bmp_buf_len = %d\n", (unsigned long)MsSinceStart, fb, bmp_buf, bmp_buf_len);
  bool converted = frame2bmp(fb, &bmp_buf, &bmp_buf_len);
  if (!converted)
    log_e("BMP Conversion failed");
  else
    Serial.printf("BMP Conversion succeeded with buf = %p, bmp_buf_len = %d\n", &bmp_buf, bmp_buf_len);
  if (!fb)
    Serial.println("Camera capture failed");
    return;
  Serial.printf("%lu: Just before esp_camera_fb_return(fb) with fb = %p\n", (unsigned long)MsSinceStart, fb);
  esp_camera_fb_return(fb);
  fb = NULL;
  delay(3000);
and here is the output:
Starting Setup()
0: Top of loop
Image acquired: fb = 3ffb9010 fb_len = 2539
536: Just before BMP conversion with fb = 0x3ffb9010, bmp_buf = 0x0, bmp_buf_len = 0
BMP Conversion succeeded with buf = 0x3ffb2248, bmp_buf_len = 49206
554: Just before esp_camera_fb_return(fb) with fb = 0x3ffb9010
3564: Top of loop
Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was unhandled.
Core  1 register dump:
PC      : 0x400d23a8  PS      : 0x00060530  A0      : 0x800d6623  A1      : 0x3ffb2240
A2      : 0x00000000  A3      : 0x00000003  A4      : 0x00000001  A5      : 0x3ffc2870
A6      : 0x3ffc2938  A7      : 0x3ffc2874  A8      : 0x800d23a6  A9      : 0x3ffb2220
A10     : 0x00000000  A11     : 0x3f400154  A12     : 0x00000000  A13     : 0x3ffb9010
A14     : 0x00000000  A15     : 0x3ffc4468  SAR     : 0x00000004  EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000004  LBEG    : 0x40087838  LEND    : 0x4008784e  LCOUNT  : 0xffffffff
Backtrace: 0x400d23a5:0x3ffb2240 0x400d6620:0x3ffb2270 0x4008aafe:0x3ffb2290
This is obviously some sort of memory overrun error, but I don't see how, as I was careful to call 'esp_camera_fb_return(fb);' and set the pointer back to NULL at the end of each iteration. Anyone see what I'm doing wrong here?
TIA
MicroController
Re: ESP32CAM Arduino program with Guru Meditation Error:
Postby MicroController » Thu Feb 20, 2025 8:11 am
You're 'taking' two frame buffers but only 'return' one of them to the driver.
Users browsing this forum: No registered users and 154 guests
