BQB Test Tool Issue with ESP32-PICO-MINI-02
hyunwook.lee
Postby hyunwook.lee » Tue Feb 18, 2025 6:32 am
I’m currently developing a wearable medical device using the ESP32-PICO-MINI-02 chipset and am in the process of completing a Blocking Test for medical device certification. We're using the BQB test tool provided by Espressif, but unfortunately, it doesn’t seem to work correctly with the ESP32-PICO-MINI-02.
Interestingly, when we run the same commands on an ESP32-WROOM-32E chipset, the tool works as expected. This leads us to suspect that the BQB test tool may not support the ESP32-PICO-MINI-02 chipset.
Has anyone experienced a similar issue or found a version of the BQB test tool that supports the ESP32-PICO-MINI-02? I’ve attached our test logs for reference.
Any insights or advice would be greatly appreciated.
Note, I used the Bluetooth signal test tool included in ESPRFTestTool.
Thank you in advance!
Hyunwook Lee
esp32-pico-mini-02 bqb log 20250218.txt
(7.77 KiB) Downloaded 54 times
hyunwook.lee
Re: BQB Test Tool Issue with ESP32-PICO-MINI-02
Postby hyunwook.lee » Fri Mar 07, 2025 8:45 am
I solved the problem using the BQB tool in the RF Test Tool.
Users browsing this forum: Bing [Bot] and 152 guests
