The project is not getting built up
sanjai s
Postby sanjai s » Fri Feb 14, 2025 7:33 am
I'm trying to make a program to configure radar sensor with ESP32, therefore I have used the reference program from Acconeer and while trying to compile the program, I was encountered with this error:
CMake Error at build/component_requires.temp.cmake:417 (__component_set_property):
Syntax error in cmake code at
C:/Users/sanja.000/esp projects/radar/build/component_requires.temp.cmake:417
when parsing string
include;C:\Users\sanja.000\esp\v5.3.2\esp-idf/components/esp_rom/include/esp32/rom/;C:\Users\sanja.000\esp\v5.3.2\esp-idf/components/freertos/FreeRTOS-Kernel/include/freertos
Invalid character escape '\U'.
C:/Users/sanja.000/esp/v5.3.2/esp-idf/tools/cmake/component.cmake:255 (include)
C:/Users/sanja.000/esp/v5.3.2/esp-idf/tools/cmake/build.cmake:586 (__component_get_requirements)
C:/Users/sanja.000/esp/v5.3.2/esp-idf/tools/cmake/project.cmake:710 (idf_build_process)
CMakeLists.txt:6 (project)
* The terminal process "C:\Users\sanja.000\.espressif\tools\cmake\3.30.2\bin\cmake.exe '-G', 'Ninja', '-DPYTHON_DEPS_CHECKED=1', '-DESP_PLATFORM=1', '-B', 'c:\Users\sanja.000\esp projects\radar\build', '-S', 'c:\Users\sanja.000\esp projects\radar', '-DSDKCONFIG=c:\Users\sanja.000\esp projects\radar\sdkconfig'" terminated with exit code: 1.
I have initial ideas of error like, the environmental variables are with undesired format, but I couldn't say its the sole proble. Please help me sorting out the program, so I work furthermore.
(PS) I'll attack the CMake files, build error file in build and the whole project file, for better understanding.
radar.zip
whole project folder
(2.19 MiB) Downloaded 20 times
CMakeLists.txt
project make file
(238 Bytes) Downloaded 15 times
CMakeLists.txt
main make file
(1.4 KiB) Downloaded 16 times
chegewara
Re: The project is not getting built up
Postby chegewara » Sat Feb 15, 2025 7:20 am
- do you have in project path spaces or special chars
- check and reformat CMakeLists files, hard to say which one; there may be some non-standard characters
MicroController
Postby MicroController » Sat Feb 15, 2025 7:49 am
Looks like, for some reason, "C:\Users\..." appears in a path instead of "C:/Users/...".
sanjai s
Postby sanjai s » Mon Feb 17, 2025 7:38 am
I knew that was the problem, but I couldn't resolve it, because I don't the source of error
Users browsing this forum: floitsch_toit and 108 guests
