Flash read performance
FaRe0001
Postby FaRe0001 » Tue Feb 11, 2025 9:18 am
Hi all,
I have tried running some benchmarks for flash read performance on my esp32-s3, and noticed that
esp_flash_read
performs about 30% slower than
esp_flash_read_encrypted
I observed the same behavior when using
esp_partition_read
and comparing performance with and without flash encryption.
Reference code below, used the same setup for esp_flash_read:
    #define NUM_BLOCKS 64
    void test_flash_read_plaintext(size_t block_size) {
    	uint8_t *flash_buffer = (uint8_t *)malloc(block_size);
    	const esp_partition_t *partition = get_partition_to_test();
    	start_time = esp_timer_get_time();
    	for (int i = 0; i < NUM_BLOCKS; i++) {
        	esp_flash_read_encrypted(NULL,partition->address + i * block_size, flash_buffer, block_size);
        end_time = esp_timer_get_time();
        printf("esp_flash_read: %llu microseconds", (end_time - start_time)/NUM_BLOCKS;
What could be the reason for this difference in performance?
FaRe0001
Re: Flash read performance
Postby FaRe0001 » Wed Feb 12, 2025 9:54 am
I got the previous results reading 4096 byte blocks.
When reading 32 byte blocks "esp_flash_read" performs much better, as would likely be expected.
Users browsing this forum: No registered users and 101 guests
