I'm having a lot of trouble with code folding in Eclipse and ESP-IDF.
When I collapse all code, and do a small edit between two folds, the whole thing goes crazy. Folds open randomly all over the code !?
What might cause this ? I've tested a lot of different Eclipse versions, but no change. Also the problem seems to be within the ESP-IDF plugin, because before the plugin is installed, folds seem to work.
Code folding problems
Re: Code folding problems
We have noted this issue. When trying to edit code within a collapsed section, the code unexpectedly expands. This behavior is quite unusual. We will look into it.
Thanks!
Thanks!
Users browsing this forum: No registered users and 43 guests
