esp-idf http post
anhchill123
esp-idf http post
Postby anhchill123 » Sat Jan 18, 2025 7:26 pm
hi to all.
I'm not good at English
i'm using esp8266 kit + php +mysql +xampp ( localhost), try to using POST request to my php. I'm able to connect to wifi rourter and using this code:
static void post_rest_function()
    esp_http_client_config_t config = {
        .url = "http://192.168.56.1/final/updateHX711data_and_recordtable.php",
        .method = HTTP_METHOD_POST,
        .cert_pem = NULL,
        .event_handler=_http_event_handler,
    const char *post_data="id=esp8266_01&name=DaoDuyAnh&weight=10.5&status_read_sensor_hx711=SUCCESS&led_01=OFF&led_02=OFF");
    esp_http_client_set_header(client, "Content-Type", "application/x-www-form-urlencoded");
    esp_http_client_set_post_field(client, post_data, strlen(post_data));
    esp_http_client_perform(client);
    esp_http_client_cleanup(client);
This is my php code :
<?php
  require 'database.php';
  if (!empty($_POST)) {
    $id = $_POST['id'];
    $weight = $_POST['weight'];
    $name = $_POST['name'];
    $status_read_sensor_hx711 = $_POST['status_read_sensor_hx711'];
    $led_01 = $_POST['led_01'];
    $led_02 = $_POST['led_02'];
    date_default_timezone_set("Etc/GMT+7"); // Look here for your timezone : https://www.php.net/manual/en/timezones.php
    $tm = date("H:i:s");
    $dt = date("Y-m-d");
    $pdo = Database::connect();
    $pdo->setAttribute(PDO::ATTR_ERRMODE, PDO::ERRMODE_EXCEPTION);
    $sql = "UPDATE 	esp8266_table_hx711_leds_update	 SET  weight = ?, status_read_sensor_hx711 = ?, time = ?, date = ? WHERE id = ?";
    $q = $pdo->prepare($sql);
    $q->execute(array($weight,$status_read_sensor_hx711,$tm,$dt,$id));
    Database::disconnect();
    function generate_string_id($strength = 16) {
    $permitted_chars = '0123456789abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ';
    $input_length = strlen($permitted_chars);
    $random_string = '';
    for($i = 0; $i < $strength; $i++) {
      $random_character = $permitted_chars[mt_rand(0, $input_length - 1)];
      $random_string .= $random_character;
    return $random_string;
i test postman to send data to "http://192.168.56.1/final/updateHX711da ... dtable.php" and success update data in mysql database but when i run the esp-idf code, i have a trouble:
"E (20789) HTTP_CLIENT: Connection failed, sock < 0
E (20790) HTTP: HTTP POST request failed: ESP_ERR_HTTP_CONNECT "
How to fix this or I use wrong way.
Thank you
Regard
nopnop2002
Contact:
Re: esp-idf http post
Postby nopnop2002 » Sun Jan 19, 2025 7:22 am
I am using this code.
I am using this as an HTTP server.
https://github.com/typicode/json-server
        .url = "http://192.168.10.43:3000/posts",
        .event_handler = _http_event_handler,
    esp_err_t err;
    // POST
    const char *post_data = "{\"id\":\"3\",\"title\":\"hohe\",\"views\":123}";
    esp_http_client_set_method(client, HTTP_METHOD_POST);
    esp_http_client_set_header(client, "Content-Type", "application/json");
    err = esp_http_client_perform(client);
    if (err == ESP_OK) {
        ESP_LOGI(TAG, "HTTP POST Status = %d, content_length = %"PRId64,
                esp_http_client_get_status_code(client),
                esp_http_client_get_content_length(client));
        ESP_LOGE(TAG, "HTTP POST request failed: %s", esp_err_to_name(err));
POST can be used for a wide range of purposes, such as creating new resources, starting batch operations, deleting data, etc., whereas PUT is more specific and is primarily used to "replace" an existing resource.
POST is widely used to add data, while PUT is widely used to update a database.
anhchill123
Postby anhchill123 » Sun Jan 19, 2025 8:00 am
        .url = "http://192.168.10.43:3000/todos",
    // POST
    const char *post_data = "{\"title\":\"hoge\",\"time\":123,\"date\":456}";
    esp_err_t err = esp_http_client_perform(client);
Hi , i don't understand. Can u explain more :(((
nopnop2002
Contact:
Postby nopnop2002 » Mon Jan 20, 2025 2:47 am
The only thing you need in the config is the url and event_handler.
you need esp_http_client_set_method befor post.
Users browsing this forum: No registered users and 100 guests
