ESP32 factory partition
ali.abbas
Postby ali.abbas » Sat Jan 18, 2025 7:10 am
I am using esp32 vs code espressif, I am using a partition with one OTA and factory. What should I do do be able to create a factory code. (What folder name should I use? do I need to change cmake?)
Thank you
chegewara
Re: ESP32 factory partition
Postby chegewara » Tue Jan 21, 2025 6:40 am
What do you mean by factory code?
Any firmware you build is a "factory" and will be flashed on factory partition unless you decide to flash on OTA.
The only difference is that you cant update factory partition easy way and after OTA update device will start from factory partition if and only if all OTA partitions are corrupted.
Users browsing this forum: No registered users and 12 guests
