UART Receive stops working after some time
Wolpertinger
Postby Wolpertinger » Mon Jan 27, 2025 11:31 am
I have a custom board with an ESP32-WROOM Module on it. When my board is running for ~30min and more the ESP32 does not receive any more UART messages. I was able to verify, that messages are sent from my board and an answer is sent back, but the ESP does not register anything.
bool ModbusRTUMaster::readInputRegisters(uint8_t id, uint16_t startAddress, uint16_t* buf, uint16_t quantity) {
    const uint8_t functionCode = 4;
    if (id < 1 || id > 247 || !buf || quantity == 0 || quantity > 125) return false;
    _buf[0] = id;
    _buf[1] = functionCode;
    _buf[2] = highByte(startAddress);
    _buf[3] = lowByte(startAddress);
    _buf[4] = highByte(quantity);
    _buf[5] = lowByte(quantity);
    _writeRequest(6);
    uint32_t startTime = esp_timer_get_time();
    size_t buffered_len;
    uart_get_buffered_data_len(_uart_num, &buffered_len);
    while (esp_timer_get_time() - startTime < 50000 && buffered_len < _bytesSent && _bytesSent > 0)
        esp_err_t error = uart_get_buffered_data_len(_uart_num, &buffered_len);
        if (error != ESP_OK)
            uart_driver_delete(_uart_num);
            uart_config_t uart_config = {
                .baud_rate = 9600,
                .parity    = UART_PARITY_DISABLE,
                .flow_ctrl = UART_HW_FLOWCTRL_DISABLE,
                .source_clk = UART_SCLK_APB
            uart_param_config(_uart_num, &uart_config);
            uart_set_pin(_uart_num, GPIO_NUM_1, GPIO_NUM_3, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE);
            uart_driver_install(_uart_num, 512, 0, 0, NULL, 0);
    while (esp_timer_get_time() - startTime < 100000 && buffered_len < 2)
    //vTaskDelay(pdMS_TO_TICKS(30)); // Delay anstelle von delay()
    uint16_t responseLength = _readResponse(id, functionCode);
    if (responseLength != (uint16_t)(3 + quantity * 2) || _buf[2] != quantity * 2) return false;
    for (uint16_t i = 0; i < quantity; i++) {
        buf[i] = _bytesToWord(_buf[4 + i * 2], _buf[3 + i * 2]);
    return true;
By debugging I was able to confirm that this code is executed. But buffered_len is always 0 after some time.
nopnop2002
Contact:
Re: UART Receive stops working after some time
Postby nopnop2002 » Wed Jan 29, 2025 3:15 am
You can perform long-term testing by connecting GPIO4 and GPIO5 with a wire and running this app.
It communicates at 1 second intervals and has been operating continuously for over 12 hours.
https://github.com/espressif/esp-idf/tr ... _rxtxtasks
Users browsing this forum: No registered users and 78 guests
