Espressif-IDE clang not formatting indentation when typing
StudlySpud
Postby StudlySpud » Thu Jan 09, 2025 12:32 am
I am using Espressif IDE version 3.1.0, and ESP-IDF version 5.3.2.
When I am typing code, it is not indenting the closing braces, or the new line for content, on statements such as 'if' or else': it puts them at the start of the line.
But if I format the document with ctrl-shift-f, it fixes the indentation.
Here is typed code:
static void test_function(void)
	if (true) {
//this is not indented!
}else {
if(true){
	//I manually indented this and the brace below
//This is still not indented!
Here is after fixing with ctrl-shift-F:
static void test_function(void) {
  if (true) {
    // this is not indented!
  if (true) {
    // I manually indented this and the brace below
    // This is still not indented!
I have the default .clang-format document at the root of my project.
# We'll use defaults from the LLVM style, but with some modifications so that it's close to the CDT K&R style.
BasedOnStyle: LLVM
UseTab: Always
IndentWidth: 4
TabWidth: 4
PackConstructorInitializers: NextLineOnly
BreakConstructorInitializers: AfterColon
IndentAccessModifiers: false
AccessModifierOffset: -4
How can I enable the IDE to do the proper indent formatting while typing code?
Thank you
ESP_kondalkolipaka
Re: Espressif-IDE clang not formatting indentation when typing
Postby ESP_kondalkolipaka » Mon Feb 17, 2025 12:29 pm
This is currently supported only on Editor Save. We will consider your request as an enhancement to further improve this functionality.
Screenshot 2025-02-17 at 5.57.43 PM.png (218.2 KiB) Viewed 1830 times
Thanks!
Users browsing this forum: No registered users and 56 guests
