RMT led encoder - Modify bytes on the fly
Xylopyrographer
Postby Xylopyrographer » Wed Jan 22, 2025 7:06 pm
Hi all. I'm working on some code based on the RMT Transmit Example -- LED Strip located here: https://github.com/espressif/esp-idf/tr ... /led_strip
I need to modify led_strip_encoder.c so that I can modify on the fly the byte pulled from the led_strip_pixels buffer before it is encoded and then sent further down the processing chain.
Need to do it this way so the bytes in the led_strip_pixels buffer remain as-is as the modification prior to encoding is destructive to the original byte value.
I don't have enough C or C++ knowledge to understand where in the led_strip_encoder.c code the byte is pulled from the buffer so if anyone can lend a hand would be very appreciated.
Last bumped by Xylopyrographer on Wed Jan 22, 2025 7:06 pm.
Users browsing this forum: No registered users and 73 guests
