E (15610) esp-tls: couldn't get hostname for :test.mosquitto.org: getaddrinfo() returns 202, addrinfo=0x0
Riqium
Postby Riqium » Fri Nov 29, 2024 11:38 pm
Hi. I've banging my head against the wall trying to solve this problem. The code is a simple application that connects to wifi and then tries to connect to an MQTT broker. Here are the logs:
I (15610) Proyecto Final: STARTING MQTT
I (15610) Proyecto Final: Other event id:7
E (15610) transport_base: Failed to open a new connection: 32769
E (15620) mqtt_client: Error transport connect
I (15630) Proyecto Final: MQTT_EVENT_ERROR
I (15630) Proyecto Final: MQTT5 return code is 0
E (15640) Proyecto Final: Last error reported from esp-tls: 0x8001
Here is the code:
(Board is an ESP32S3 DevKit)
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <stdint.h>
#include <stddef.h>
#include <esp_netif.h>
#include <esp_system.h>
#include <esp_log.h>
#include <esp_event.h>
#include <nvs_flash.h>
#include <esp_wifi.h>
#include <mqtt_client.h>
#include <freertos/FreeRTOS.h>
#include <freertos/task.h>
#include <freertos/event_groups.h>
// #define LED 13
// #define PB
#define OFF 0      // ESTADO APAGADO
#define MEDIUM 1   // ESTADO PARPADEO 0.5s
#define FAST 2     // ESTADO PARPADEO 0.1s
#define SLOW 3     // ESTADO PARPADEO 1s
#define VARIABLE 4 // ESTADO PARPADEO VARIABLE
#define SSID "xxx"
#define PASS "xxx"
static const char *TAG = "Proyecto Final";
static const char *topic = "micro/esp32s3/pf";
bool wifi_connected = false; // ESTADO WIFI
bool mqtt_connected = false; // ESTADO MQTT
static void log_error_if_nonzero(const char *message, int error_code)
    if (error_code != 0) {
        ESP_LOGE(TAG, "Last error %s: 0x%x", message, error_code);
struct IO_DATA
    bool pb;
    bool led;
} io_data;
uint8_t prev_state = OFF;
uint8_t curr_state = OFF;
// uint8_t next_state = 0;
/*-------- FSM FUNCTIONS --------*/
int offFunc(void)
    prev_state = curr_state;
    curr_state = OFF;
    while (1)
        if (io_data.pb == true)
            io_data.pb = false;
            return MEDIUM;
int mediumFunc(void)
    curr_state = MEDIUM;
    while (1)
            io_data.pb = false;
            return FAST;
int fastFunc(void)
    curr_state = FAST;
    while (1)
            io_data.pb = false;
            return SLOW;
int slowFunc(void)
    curr_state = SLOW;
    while (1)
            io_data.pb = false;
            return VARIABLE;
int varFunc(void)
    curr_state = VARIABLE;
    while (1)
            io_data.pb = false;
            return OFF;
/*-------- MQTT EVENT HANDLER --------*/
static void mqtt5_event_handler(void *handler_args, esp_event_base_t base, int32_t event_id, void *event_data)
    ESP_LOGD(TAG, "Event dispatched from event loop base=%s, event_id=%" PRIi32, base, event_id);
    esp_mqtt_event_handle_t event = event_data;
    esp_mqtt_client_handle_t client = event->client;
    int msg_id = 0;
    ESP_LOGD(TAG, "free heap size is %" PRIu32 ", minimum %" PRIu32, esp_get_free_heap_size(), esp_get_minimum_free_heap_size());
    switch ((esp_mqtt_event_id_t)event_id)
    case MQTT_EVENT_CONNECTED:
        ESP_LOGI(TAG, "MQTT_EVENT_CONNECTED");
        mqtt_connected = true;
        // Subscripcion
        //msg_id = esp_mqtt_client_subscribe(client, topic, 1);
    case MQTT_EVENT_DISCONNECTED:
        ESP_LOGI(TAG, "MQTT_EVENT_DISCONNECTED");
    case MQTT_EVENT_SUBSCRIBED:
        ESP_LOGI(TAG, "MQTT_EVENT_SUBSCRIBED, msg_id=%d", event->msg_id);
        ESP_LOGI(TAG, "sent publish successful, msg_id=%d", msg_id);
        //msg_id = esp_mqtt_client_publish(client, topic, "entro eri", sizeof("entro eri"), 1, 1);
    case MQTT_EVENT_UNSUBSCRIBED:
        ESP_LOGI(TAG, "MQTT_EVENT_UNSUBSCRIBED, msg_id=%d", event->msg_id);
    case MQTT_EVENT_PUBLISHED:
        ESP_LOGI(TAG, "MQTT_EVENT_PUBLISHED, msg_id=%d", event->msg_id);
        ESP_LOGI(TAG, "Published @ micro.");
    case MQTT_EVENT_DATA:
        ESP_LOGI(TAG, "MQTT_EVENT_DATA");
    case MQTT_EVENT_ERROR:
        ESP_LOGI(TAG, "MQTT_EVENT_ERROR");
        ESP_LOGI(TAG, "MQTT5 return code is %d", event->error_handle->connect_return_code);
        if (event->error_handle->error_type == MQTT_ERROR_TYPE_TCP_TRANSPORT)
            log_error_if_nonzero("reported from esp-tls", event->error_handle->esp_tls_last_esp_err);
            log_error_if_nonzero("reported from tls stack", event->error_handle->esp_tls_stack_err);
            log_error_if_nonzero("captured as transport's socket errno", event->error_handle->esp_transport_sock_errno);
            ESP_LOGI(TAG, "Last errno string (%s)", strerror(event->error_handle->esp_transport_sock_errno));
    default:
        ESP_LOGI(TAG, "Other event id:%d", event->event_id);
/*-------- WIFI EVENT HANDLER --------*/
static void wifi_event_handler(void *event_handler_arg, esp_event_base_t event_base, int32_t event_id, void *event_data)
    uint8_t retry_num = 0;
    if (event_id == WIFI_EVENT_STA_START)
        ESP_LOGI(TAG, "WIFI CONNECTING...");
    else if (event_id == WIFI_EVENT_STA_CONNECTED)
        ESP_LOGI(TAG, "WiFi CONNECTED");
        wifi_connected = true;
    else if (event_id == WIFI_EVENT_STA_DISCONNECTED)
        ESP_LOGI(TAG, "WiFi DISCONNECTED");
        if (retry_num < 10)
            esp_wifi_connect();
            retry_num++;
            ESP_LOGI(TAG, "RETRYING...");
    else if (event_id == IP_EVENT_STA_GOT_IP)
        ESP_LOGI(TAG, "IP GOTTEN");
/*-------- WIFI INIT CONFIG --------*/
void wifi_init(void)
    // ESP_ERROR_CHECK(esp_netif_init());                      //Init interfaz de red
    // ESP_ERROR_CHECK(esp_event_loop_create_default());
    wifi_init_config_t wifi_init = WIFI_INIT_CONFIG_DEFAULT(); // Config INIT por defecto
    esp_wifi_init(&wifi_init);
    esp_event_handler_register(WIFI_EVENT, ESP_EVENT_ANY_ID, wifi_event_handler, NULL); // Registro de función de evento wifi
    wifi_config_t wifi_config = {
        .sta = {
            .ssid = "",
            .password = ""}};
    strcpy((char *)wifi_config.sta.ssid, SSID);
    strcpy((char *)wifi_config.sta.password, PASS);
    esp_wifi_set_mode(WIFI_MODE_STA);                   // Seleccion STA
    esp_wifi_set_config(ESP_IF_WIFI_STA, &wifi_config); // Config STA
    esp_wifi_start();                                   // Iniciar WIFI
/*-------- MQTT CLIENT CONFIG --------*/
esp_mqtt_client_handle_t client = NULL;
static void mqtt5_app_start(void)
    ESP_LOGI(TAG, "STARTING MQTT");
    esp_mqtt_client_config_t mqttConfig = {
        .broker.address.uri = "mqtt://test.mosquitto.org:1883",
        .session.protocol_ver = MQTT_PROTOCOL_V_5,
        .network.disable_auto_reconnect = false,
        .credentials.username = "",
        .credentials.authentication.password = ""};
    client = esp_mqtt_client_init(&mqttConfig);
    esp_mqtt_client_register_event(client, ESP_EVENT_ANY_ID, mqtt5_event_handler, client);
    esp_mqtt_client_start(client);
void app_main(void)
    if (ret == ESP_ERR_NVS_NO_FREE_PAGES || ret == ESP_ERR_NVS_NEW_VERSION_FOUND)
    ESP_ERROR_CHECK(ret);
    wifi_init();
    while (wifi_connected != true)
        esp_wifi_connect();                    // Conectar
        vTaskDelay(5000 / portTICK_PERIOD_MS); // Delay para darle chance
    ESP_ERROR_CHECK(esp_netif_init()); // Init interfaz de red
    while (mqtt_connected != true)
        mqtt5_app_start();
Users browsing this forum: Google [Bot] and 52 guests
