esp32 ble suspend inside registerForNotify
esp32New956832
Postby esp32New956832 » Sun Nov 24, 2024 1:52 pm
Hi
I am newbie in esp32.
I would like connect to BLE device make few requests and disconnect, and repeat it periodically.
The main problem is - device freeze inside BLE api registerForNotify , it happens seldom if signal good and often(on 3-5 request) if poor .
I think problem happen when we inside registerForNotify and callback disconnect event happen.
Board: ESP32 LILYGO T-Display v1.1 4MB.
Code:
//  if ( stop_work )
  //  return ;
  uint32_t cur_ms = millis();
  switch( status ){
    case(0):
      if ( JkBms.connect() ){
        tft.fillScreen(TFT_BLACK);
        tft.setCursor(0, 0);
        tft.printf( "connected. up:%dmin\n", (millis() - uptime)/60000);
        status = 1;
      }else{
        tft.printf( "fail conn. up:%dmin\n", (millis() - uptime)/60000);
        if ( printLinCur >= 13 ){
          printLinCur = 0;
        ESP_LOGD("", "fail conn. up:%dmin\n", (millis() - uptime)/60000);
        printLinCur += 1;
      delay(1500);
      last_event_ms = millis();
    case(1):
      if (cur_ms - last_event_ms > 30000){
        ESP_LOGD("", "disconnect, uptime %dmin", (cur_ms - uptime)/60000);
        tft.printf( "disconnect, uptime %dmin\n", (cur_ms - uptime)/60000);
        JkBms.disconnect();
        status = 2;
    case(2):
        if (cur_ms - last_event_ms > 20000){
          ESP_LOGD("", "restart switch, uptime %dmin", (cur_ms - uptime)/60000);
          tft.printf("restart switch, uptime %dmin\n", (cur_ms - uptime)/60000);
          status = 0;
          last_event_ms = cur_ms;
          delay(1500);
    default:
class MyAdvertisedDeviceCallbacks : public BLEAdvertisedDeviceCallbacks {
  void onResult(BLEAdvertisedDevice advertisedDevice) {
    ESP_LOGD(TAG, "Advertised Device: %s \n", advertisedDevice.toString().c_str());
    if (!advertisedDevice.getAddress().equals(BLE_JKBMS_ADDR)) {
      ESP_LOGI(TAG, "Skip: %s", advertisedDevice.toString().c_str());
      return ;
    for (int i = 0; i < advertisedDevice.getServiceUUIDCount(); ++i) {
      if (advertisedDevice.getServiceUUID(i).equals(jkbms_service_UUID)) {
        ESP_LOGD(TAG, "found device, stop scan.");
        pBLEScan->stop();
        myDevice = new BLEAdvertisedDevice(advertisedDevice);
        ESP_LOGI(TAG, "Choice %s", advertisedDevice.toString().c_str());
class MyClientCallback : public BLEClientCallbacks {
  void onConnect(BLEClient* pclient) {
    connected = true;
    ESP_LOGI(TAG, "onConnect %s", pclient->toString().c_str());
 void onDisconnect(BLEClient* pclient) {
    connected = false;
    ESP_LOGI(TAG, "onDisconnect");
void BLE_BMS_JK::setup() {
  BLEDevice::init("");
  if (pMyAdvertisedDeviceCallbacks != nullptr) {
    ESP_LOGE(TAG, "already called setup");
    return;
  pMyAdvertisedDeviceCallbacks = new MyAdvertisedDeviceCallbacks();
  pBLEScan = BLEDevice::getScan();  //create new scan
  pBLEScan->setAdvertisedDeviceCallbacks(pMyAdvertisedDeviceCallbacks);
  pBLEScan->setActiveScan(true);  //active scan uses more power, but get results faster
  pBLEScan->setInterval(300);
  pBLEScan->setWindow(200);  // less or equal setInterval value
bool BLE_BMS_JK::connect() {
  if ( pClient ){
    if ( pClient->isConnected() ){
      return true;
  ESP_LOGD(TAG, "Forming a connection");
  connected = false;
  pBLEScan->clearResults();
  if ( !pBLEScan->start(m_scanTime) )
    return false;
   if ( !myDevice )
    return false;
  int status = -1;
  do{
    if ( !pMyClientCallback )
      pMyClientCallback = new MyClientCallback();
    if ( !pClient )
     pClient = BLEDevice::createClient();
    if ( !pMyClientCallback ||  !pClient){
      ESP_LOGE(TAG, "fail create ClientCallback or Client");
    pClient->setClientCallbacks(pMyClientCallback);
    ESP_LOGD(TAG, "pClient->connect");
    if (!pClient->connect(myDevice)){
      ESP_LOGI(TAG, "Fail connect");
    delay(100);
   BLERemoteService* pRemoteService = pClient->getService(jkbms_service_UUID);
    if (pRemoteService == nullptr) {
      ESP_LOGE(TAG, "Failed to find our service UUID: %s", jkbms_service_UUID.toString().c_str());
    ESP_LOGD(TAG, " - Found our service");
    delay(100);
  pRemoteCharacteristic = pRemoteService->getCharacteristic(charUUID);
    if (pRemoteCharacteristic == nullptr) {
      ESP_LOGE(TAG, "Failed to find our characteristic UUID: %s", charUUID.toString().c_str());
    ESP_LOGD(TAG, "pRemoteCharacteristic = %s", pRemoteCharacteristic->toString().c_str());
    delay(100);
    if ( !connected )
      ESP_LOGI(TAG, "not connected");
    ESP_LOGD(TAG, "canNotify");
    if ([b]!pRemoteCharacteristic->canNotify()[/b]){
      ESP_LOGE(TAG, "No notify characteristic");
    ESP_LOGD(TAG, "registerForNotify");
    pRemoteCharacteristic->registerForNotify(notifyCallback);
    ESP_LOGD(TAG, "conn status OK");
    status = 0;
  }while(0);
  if ( status != 0)
    if ( pClient )
        pClient->disconnect();
    if ( pRemoteCharacteristic != nullptr)
      pRemoteCharacteristic->registerForNotify(nullptr);
    pRemoteCharacteristic = nullptr;
    if (myDevice != nullptr){
      delete myDevice;
    myDevice = nullptr;
  else
    ESP_LOGD(TAG, "GetDevInfo");
    getDeviceInfo(pRemoteCharacteristic);
  return status == 0;
void BLE_BMS_JK::disconnect(){
  if (  pClient == nullptr )
      return ;
  ESP_LOGD(TAG, "disconnect: %s", myDevice->toString().c_str());
      pRemoteCharacteristic->registerForNotify(nullptr);  // unregister callback ?
  if ( myDevice != nullptr )
      delete myDevice;
      myDevice = nullptr;
static void notifyCallback(
  BLERemoteCharacteristic* pBLERemoteCharacteristic,
  uint8_t* pData,
  size_t length,
  bool isNotify)
    tLastNotify_ms = millis();
    // Flush buffer on every preamble
    if (pData[0] == 0x55 && pData[1] == 0xAA && pData[2] == 0xEB && pData[3] == 0x90) {
      frame_buffer.clear();
    frame_buffer.insert(frame_buffer.end(), pData, pData + length);
  if (frame_buffer.size() >= MIN_RESPONSE_SIZE) {
    const uint8_t *raw = &frame_buffer[0];
    // Even if the frame is 320 bytes long the CRC is at position 300 in front of 0xAA 0x55 0x90 0xEB
    const uint16_t frame_size = MIN_RESPONSE_SIZE;  // this->frame_buffer_.size();
    uint8_t computed_crc = crc(raw, frame_size - 1);
    uint8_t remote_crc = raw[frame_size - 1];
    if (computed_crc != remote_crc) {
      ESP_LOGE(TAG, "CRC check failed! 0x%02X != 0x%02X", computed_crc, remote_crc);
      return;
    std::vector<uint8_t> data(frame_buffer.begin(), frame_buffer.end());
    decode(data);
  //  status_notify = 1;
Connection log:
[ 72991][D][BLE_BMS.cpp:181] connect(): [BLE_BMS] canNotify
[ 72996][D][BLE_BMS.cpp:187] connect(): [BLE_BMS] registerForNotify
[ 73002][V][BLERemoteCharacteristic.cpp:452] registerForNotify(): >> registerForNotify(): .....
[ 73085][V][BLERemoteDescriptor.cpp:162] writeValue(): >> writeValue: handle: 19, uuid: 00002902-0000-1000-8000-00805f9b34fb
[ 73146][V][FreeRTOS.cpp:59] wait(): >> wait: Semaphore waiting: name: WriteDescrEvt (0x3ffe6240), owner: writeValue for writeValue
[ 85886][BLE_BMS.cpp:89] onDisconnect(): [BLE_BMS] onDisconnect
[ 85946][V][BLEUtils.cpp:1214] dumpGattClientEvent(): [status: ESP_GATT_OK, reason:ESP_GATT_CONN_TIMEOUT, conn_id: 0]
[ 72764][D][BLE_BMS.cpp:162] connect(): [BLE_BMS]  - Found our service
[ 72870][D][BLE_BMS.cpp:172] connect(): [BLE_BMS] pRemoteCharacteristic = Characteristic: uuid: 0000ffe1-0000-1000-8000-00805f9b34fb, handle: 18 0x0012, props: broadcast: 0, read: 0, write_nr: 1, write: 1, noti0
[ 73002][V][BLERemoteCharacteristic.cpp:452] registerForNotify(): >> registerForNotify(): Characteristic: uuid: 0000ffe1-0000-1000-8000-00805f9b34fb, handle: 18 0x0012, props: broadcast: 0, read: 0, write_nr: 10
[ 73025][V][FreeRTOS.cpp:179] take(): Semaphore taking: name: RegForNotifyEvt (0x3ffe6074), owner: <N/A> for registerForNotify
[ 73036][V][FreeRTOS.cpp:188] take(): Semaphore taken:  name: RegForNotifyEvt (0x3ffe6074), owner: registerForNotify
[ 73047][V][BLERemoteCharacteristic.cpp:331] getDescriptor(): >> getDescriptor: uuid: 00002902-0000-1000-8000-00805f9b34fb
[ 73047][D][BLEDevice.cpp:138] gattClientEventHandler(): gattClientEventHandler [esp_gatt_if: 4] ... ESP_GATTC_REG_FOR_NOTIFY_EVT
[ 73069][V][BLERemoteCharacteristic.cpp:335] getDescriptor(): << getDescriptor: found
[ 73069][V][BLEUtils.cpp:1202] dumpGattClientEvent(): GATT Event: ESP_GATTC_REG_FOR_NOTIFY_EVT
[ 73085][V][BLEUtils.cpp:1368] dumpGattClientEvent(): [status: ESP_GATT_OK, handle: 18 0x12]
[ 73104][V][FreeRTOS.cpp:179] take(): Semaphore taking: name: WriteDescrEvt (0x3ffe6240), owner: <N/A> for writeValue
[ 73104][D][BLEClient.cpp:185] gattClientEventHandler(): gattClientEventHandler [esp_gatt_if: 4] ... ESP_GATTC_REG_FOR_NOTIFY_EVT
[ 73126][V][FreeRTOS.cpp:188] take(): Semaphore taken:  name: WriteDescrEvt (0x3ffe6240), owner: writeValue
[ 73126][V][FreeRTOS.cpp:136] give(): Semaphore giving: name: RegForNotifyEvt (0x3ffe6074), owner: registerForNotify
[ 76072][V][BLEUtils.cpp:967] dumpGapEvent(): Received a GAP event: ESP_GAP_BLE_UPDATE_CONN_PARAMS_EVT
[ 76081][V][BLEUtils.cpp:1170] dumpGapEvent(): [status: 0, bd_addr: c8:47:80:19:16:25, min_int: 12, max_int: 16, latency: 0, conn_int: 16, timeout: 600]
[ 76094][D][BLEClient.cpp:496] handleGAPEvent(): BLEClient ... handling GAP event!
llcp prog: 438 1 269 0 0
[ 85810][D][BLEDevice.cpp:138] gattClientEventHandler(): gattClientEventHandler [esp_gatt_if: 4] ... ESP_GATTC_DISCONNECT_EVT
[ 85821][V][BLEUtils.cpp:1202] dumpGattClientEvent(): GATT Event: ESP_GATTC_DISCONNECT_EVT
[ 85829][V][BLEUtils.cpp:1241] dumpGattClientEvent(): [reason: ESP_GATT_CONN_TIMEOUT, conn_id: 0, remote_bda: c8:47:80:19:16:25]
[ 85840][D][BLEClient.cpp:185] gattClientEventHandler(): gattClientEventHandler [esp_gatt_if: 4] ... ESP_GATTC_DISCONNECT_EVT
[ 85852][V][FreeRTOS.cpp:136] give(): Semaphore giving: name: OpenEvt (0x3ffe261c), owner: <N/A>
[ 85860][V][FreeRTOS.cpp:136] give(): Semaphore giving: name: RssiCmplEvt (0x3ffe2720), owner: <N/A>
[ 85869][V][FreeRTOS.cpp:136] give(): Semaphore giving: name: SearchCmplEvt (0x3ffe2680), owner: <N/A>
[ 85878][I][BLEDevice.cpp:609] removePeerDevice(): remove: 1, GATT role client
[ 85886][I][BLE_BMS.cpp:89] onDisconnect(): [BLE_BMS] onDisconnect
[ 85891][V][FreeRTOS.cpp:136] give(): Semaphore giving: name: ReadCharEvt (0x3ffe5d2c), owner: <N/A>
[ 85900][V][FreeRTOS.cpp:136] give(): Semaphore giving: name: WriteCharEvt (0x3ffe5df4), owner: <N/A>
[ 85910][V][FreeRTOS.cpp:136] give(): Semaphore giving: name: ReadCharEvt (0x3ffe6010), owner: <N/A>
[ 85919][V][FreeRTOS.cpp:136] give(): Semaphore giving: name: WriteCharEvt (0x3ffe60d8), owner: <N/A>
[ 85928][D][BLEDevice.cpp:138] gattClientEventHandler(): gattClientEventHandler [esp_gatt_if: 4] ... ESP_GATTC_CLOSE_EVT
[ 85938][V][BLEUtils.cpp:1202] dumpGattClientEvent(): GATT Event: ESP_GATTC_CLOSE_EVT
[ 85957][D][BLEDevice.cpp:138] gattClientEventHandler(): gattClientEventHandler [esp_gatt_if: 4] ... ESP_GATTC_UNREG_EVT
[ 85967][V][BLEUtils.cpp:1202] dumpGattClientEvent(): GATT Event: ESP_GATTC_UNREG_EVT
no any responses ...
void BLERemoteCharacteristic::registerForNotify(notify_callback notifyCallback, bool notifications) {
	ESP_LOGD(LOG_TAG, ">> registerForNotify(): %s", toString().c_str());
	m_notifyCallback = notifyCallback;   // Save the notification callback.
	if (notifyCallback != nullptr) {   // If we have a callback function, then this is a registration.
		esp_err_t errRc = ::esp_ble_gattc_register_for_notify(
			m_pRemoteService->getClient()->getGattcIf(),
			*m_pRemoteService->getClient()->getPeerAddress().getNative(),
			getHandle()
		if (errRc != ESP_OK) {
			ESP_LOGE(LOG_TAG, "esp_ble_gattc_register_for_notify: rc=%d %s", errRc, GeneralUtils::errorToString(errRc));
		uint8_t val[] = {0x01, 0x00};
		if(!notifications) val[0] = 0x02;
		BLERemoteDescriptor* desc = getDescriptor(BLEUUID((uint16_t)0x2902));
		if(desc != nullptr)
			desc->writeValue(val, 2);
	} // End Register
	m_semaphoreRegForNotifyEvt.wait("registerForNotify");  /// Looks Like suspend here
	ESP_LOGD(LOG_TAG, "<< registerForNotify()");
} // registerForNotify
esp32New956832
Re: esp32 ble suspend inside registerForNotify
Postby esp32New956832 » Mon Nov 25, 2024 5:20 am
I remove from code
pRemoteCharacteristic->registerForNotify(nullptr); when disconnect device.
And now it still suspend inside registerForNotify when try write 1 to descriptor 0x2902 . As i understood it happen when code call registerForNotify but device receive disconnect event.
  ESP_LOGD(TAG, "connect");
  if ( pClient ){
      return true;
  ESP_LOGD(TAG, "start scan");
  connected = false;
    return false;
   if ( !myDevice )
    return false;
  int status = -1;
  do{
    if ( !pClient )
    if (  !pClient){
      ESP_LOGE(TAG, "fail create  Client");
    if (!pClient->connect(myDevice) ){
    delay(100);
    delay(100);
    delay(100);
    if ( !connected )
    if (!pRemoteCharacteristic->canNotify()){
    status = 0;
  }while(0);
[2024-11-25 06:52:43.826] [3051139][D][BLE_BMS.cpp:160] connect(): [BLE_BMS]  - Found our service
[2024-11-25 06:52:43.942] [3051245][D][BLE_BMS.cpp:170] connect(): [BLE_BMS] pRemoteCharacteristic = Characteristic: uuid: 0000ffe1-0000-1000-8000-00805f9b34fb, handle: 18 0x0012, props: broadcast: 0, read: 0, write_nr: 1, write: 1, notify: 1, indicate: 0, auth: 0
[2024-11-25 06:52:44.062] [3051366][D][BLE_BMS.cpp:179] connect(): [BLE_BMS] canNotify
[2024-11-25 06:52:44.063] [3051372][D][BLE_BMS.cpp:185] connect(): [BLE_BMS] registerForNotify
[2024-11-25 06:52:44.074] [3051378][V][BLERemoteCharacteristic.cpp:452] registerForNotify(): >> registerForNotify(): Characteristic: uuid: 0000ffe1-0000-1000-8000-00805f9b34fb, handle: 18 0x0012, props: broadcast: 0, read: 0, write_nr: 1, write: 1, notify: 1, indicate: 0, auth: 0
[2024-11-25 06:52:44.097] [3051400][V][FreeRTOS.cpp:179] take(): Semaphore taking: name: RegForNotifyEvt (0x3ffe604c), owner: <N/A> for registerForNotify
[2024-11-25 06:52:44.108] [3051412][V][FreeRTOS.cpp:188] take(): Semaphore taken:  name: RegForNotifyEvt (0x3ffe604c), owner: registerForNotify
[2024-11-25 06:52:44.109] [3051422][V][BLERemoteCharacteristic.cpp:331] getDescriptor(): >> getDescriptor: uuid: 00002902-0000-1000-8000-00805f9b34fb
[2024-11-25 06:52:44.120] [3051422][D][BLEDevice.cpp:138] gattClientEventHandler(): gattClientEventHandler [esp_gatt_if: 4] ... ESP_GATTC_REG_FOR_NOTIFY_EVT
[2024-11-25 06:52:44.131] [3051445][V][BLEUtils.cpp:1202] dumpGatt[C3l0i5e1n4t4E5v]e[nVt]([)B:L EGRAeTmTo tEevCehnatr:a cEtSePr_iGsAtTiTcC._cRpEpG:_3F3O5R]_NOTDFY_EVT
[2024-11-25 06:52:44.145] r(): << getDescriptor: found
[2024-11-25 06:52:44.156] [3051460][V][BLERe[m3o0t5e1D4e6s0c]r[iVp]t[oBrL.EcUptpi:l1s6.2c]p pw:r1i3t6e8V]a lduuem(p)G:a t>t>C lwireintteEVvaelnute(:) :h a[stltus: ESP_GATT 0000290dle000-1000-8000-0012]9
[2024-11-25 06:52:44.168] 34fb
[2024-11-25 06:52:44.168] [3051476][V][FreeRTOS.cpp:179] take(): Semaphore taking: name: WriteDescrEvt (0x3ffe6218), owner: <N/A> for writeValue
[2024-11-25 06:52:44.179] [3051476][D][BLEClient.cpp:185] gattClientEventHandler(): gattClientEventHandler [esp_gatt_if: 4] ... ESP_GATTC_REG_FOR_NOTIFY_EVT
[2024-11-25 06:52:44.190] [3051498][V][FreeRTOS.cpp:188] take(): Semaphore taken:  name: WriteDescrEvt (0x3ffe6218), owner: writeValue
[2024-11-25 06:52:44.201] [3051498][V][FreeRTOS.cpp:136] give(): Semaphore giving: name: RegForNotifyEvt (0x3ffe604c), owner: registerForNotify
[2024-11-25 06:52:44.214] [3051518][V][FreeRTOS.cpp:59] wait(): >> wait: Semaphore waiting: name: WriteDescrEvt (0x3ffe6218), owner: writeValue for writeValue
[2024-11-25 06:52:44.489] [3051793][V][BLEUtils.cpp:967] dumpGapEvent(): Received a GAP event: ESP_GAP_BLE_UPDATE_CONN_PARAMS_EVT
[2024-11-25 06:52:44.490] [3051802][V][BLEUtils.cpp:1170] dumpGapEvent(): [status: 0, bd_addr: c8:47:80:19:16:25, min_int: 12, max_int: 16, latency: 0, conn_int: 16, timeout: 600]
[2024-11-25 06:52:44.508] [3051816][D][BLEClient.cpp:496] handleGAPEvent(): BLEClient ... handling GAP event!
[2024-11-25 06:52:56.459] [3063763][D][BLEDevice.cpp:138] gattClientEventHandler(): gattClientEventHandler [esp_gatt_if: 4] ... ESP_GATTC_DISCONNECT_EVT
[2024-11-25 06:52:56.470] [3063774][V][BLEUtils.cpp:1202] dumpGattClientEvent(): GATT Event: ESP_GATTC_DISCONNECT_EVT
[2024-11-25 06:52:56.471] [3063782][V][BLEUtils.cpp:1241] dumpGattClientEvent(): [reason: ESP_GATT_CONN_TIMEOUT, conn_id: 0, remote_bda: c8:47:80:19:16:25]
[2024-11-25 06:52:56.482] [3063794][D][BLEClient.cpp:185] gattClientEventHandler(): gattClientEventHandler [esp_gatt_if: 4] ... ESP_GATTC_DISCONNECT_EVT
[2024-11-25 06:52:56.493] [3063805][V][FreeRTOS.cpp:136] give(): Semaphore giving: name: OpenEvt (0x3ffe24b4), owner: <N/A>
[2024-11-25 06:52:56.505] [3063814][V][FreeRTOS.cpp:136] give(): Semaphore giving: name: RssiCmplEvt (0x3ffe257c), owner: <N/A>
[2024-11-25 06:52:56.516] [3063823][V][FreeRTOS.cpp:136] give(): Semaphore giving: name: SearchCmplEvt (0x3ffe2518), owner: <N/A>
[2024-11-25 06:52:56.527] [3063832][I][BLEDevice.cpp:609] removePeerDevice(): remove: 15, GATT role client
[2024-11-25 06:52:56.527] [3063839][I][BLE_BMS.cpp:89] onDisconnect(): [BLE_BMS] onDisconnect
[2024-11-25 06:52:56.538] [3063845][V][BLEClient.cpp:171] disconnect(): >> disconnect()
[2024-11-25 06:52:56.538] [3063851][V][BLEClient.cpp:177] disconnect(): << disconnect()
[2024-11-25 06:52:56.549] [3063856][V][FreeRTOS.cpp:136] give(): Semaphore giving: name: ReadCharEvt (0x3ffe5ce4), owner: <N/A>
[2024-11-25 06:52:56.561] [3063865][V][FreeRTOS.cpp:136] give(): Semaphore giving: name: WriteCharEvt (0x3ffe5dcc), owner: <N/A>
[2024-11-25 06:52:56.561] [3063875][V][FreeRTOS.cpp:136] give(): Semaphore giving: name: ReadCharEvt (0x3ffe5fe8), owner: <N/A>
[2024-11-25 06:52:56.572] [3063884][V][FreeRTOS.cpp:136] give(): Semaphore giving: name: WriteCharEvt (0x3ffe60b0), owner: <N/A>
[2024-11-25 06:52:56.578] [3063893][D][BLEDevice.cpp:138] gattClientEventHandler(): gattClientEventHandler [esp_gatt_if: 4] ... ESP_GATTC_CLOSE_EVT
[2024-11-25 06:52:56.590] [3063904][V][BLEUtils.cpp:1202] dumpGattClientEvent(): GATT Event: ESP_GATTC_CLOSE_EVT
[2024-11-25 06:52:56.601] [3063912][V][BLEUtils.cpp:1214] dumpGattClientEvent(): [status: ESP_GATT_OK, reason:ESP_GATT_CONN_TIMEOUT, conn_id: 0]
[2024-11-25 06:52:56.619] [3063922][D][BLEDevice.cpp:138] gattClientEventHandler(): gattClientEventHandler [esp_gatt_if: 4] ... ESP_GATTC_UNREG_EVT
[2024-11-25 06:52:56.619] [3063933][V][BLEUtils.cpp:1202] dumpGattClientEvent(): GATT Event: ESP_GATTC_UNREG_EVT
Interesting part:
[BLERemoteCharacteristic.cpp:331] getDescriptor(): >> getDescriptor: uuid: 00002902 /* in registerForNotify BLERemoteDescriptor* desc = getDescriptor(BLEUUID((uint16_t)0x2902));  */
esp32New956832
Postby esp32New956832 » Wed Nov 27, 2024 2:25 pm
I have solved problem.
Problem was inside BLE library, it use semaphore for waiting event (connect/scan/RegisterNotify) but without timeout, sometimes this event BLE library dont receive as result we wait infinite time. I have changed m_semaphore.Wait to to m_semaphore.timedWait
Users browsing this forum: Majestic-12 [Bot] and 117 guests
