Problem with esp_dsp library
Kniroxe
Postby Kniroxe » Fri Nov 15, 2024 10:30 pm
Hi, I'm trying to work with the esp_dsp library, so I tested the FIR example to see how filters work on the ESP32. However, I have a problem with the dsps_tone_gen_f32 function and the FFT. In the example, the dsps_tone_gen_f32 function is used to generate two signals, and I modified it to work with only one signal. But when I applied the FFT, the result didn't match the signal.
I sent the signal generated with dsps_tone_gen_f32 through the serial port and graphed it in Excel. The graph looks like a sine wave, as expected. However, if I process the signal in Python and apply the FFT in Python, the result is also incorrect. So, how does dsps_tone_gen_f32 work?
According to the documentation, it appears as dsps_tone_gen_f32(float *output, int len, float Ampl, float freq, float phase), where freq is in terms of the Nyquist frequency. I understand that if I use dsps_tone_gen_f32(tone_2, N_buff, 5, 0.4, 0);, it corresponds to a 400 Hz signal. Is that correct?
Part of the data signal plot in excel
Python FFT
ESP32 FFT
Modified example code
 * SPDX-FileCopyrightText: 2022 Espressif Systems (Shanghai) CO LTD
 * SPDX-License-Identifier: Apache-2.0
#include <stdio.h>
#include <stdlib.h>
#include "freertos/task.h"
#include "esp_system.h"
#include "driver/spi_master.h"
#include "soc/gpio_struct.h"
#include "driver/gpio.h"
#include "driver/uart.h"
#include "soc/uart_struct.h"
#include <math.h>
#include <malloc.h>
#include "esp_dsp.h"
static const char *TAG = "main";
// This example shows how to use FIR filters from esp-dsp library
#define FIR_COEFFS_LEN      64                              // Number of FIR filter coefficients
#define DECIMATION          2                               // Decimation ratio of the FIR filter
#define N_SAMPLES           1024                            // Input samples
#define FIR_DELAY           (FIR_COEFFS_LEN / DECIMATION)   // Amount of samples not being considered for the FFT
#define FIR_BUFF_OUT_LEN    (N_SAMPLES + FIR_DELAY)         // Total length of samples
// Function shows the result of the FIR filter
void show_FFT(float *input_signal, const unsigned int fft_len)
    dsps_fft2r_fc32(input_signal, fft_len >> 1);
    dsps_bit_rev2r_fc32(input_signal, fft_len >> 1);
    dsps_cplx2real_fc32(input_signal, fft_len >> 1);
    // Correction factor for the FFT spectrum
    const float correction_factor = fft_len * 3;
    // Calculating power of spectrum in dB
    for (int i = 0 ; i < fft_len / 2 ; i++) {
        input_signal[i] = 10 * log10f((input_signal[i * 2 + 0] * input_signal[i * 2 + 0] + input_signal[i * 2 + 1] * input_signal[i * 2 + 1] + 0.0000001) / correction_factor);
    // Display power spectrum
    dsps_view(input_signal, fft_len / 2, 64, 10,  -120, 40, '|');
// Generate Windowed-Sinc filter coefficients
void generate_FIR_coefficients(float *fir_coeffs, const unsigned int fir_len, const float ft)
    // Even or odd length of the FIR filter
    const bool is_odd = (fir_len % 2) ? (true) : (false);
    const float fir_order = (float)(fir_len - 1);
    // Window coefficients
    float *fir_window = (float *)malloc(fir_len * sizeof(float));
    dsps_wind_blackman_f32(fir_window, fir_len);
    for (int i = 0; i < fir_len; i++) {
        if ((i == fir_order / 2) && (is_odd)) {
            fir_coeffs[i] = 2 * ft;
            fir_coeffs[i] = sinf((2 * M_PI * ft * (i - fir_order / 2))) / (M_PI * (i - fir_order / 2));
        fir_coeffs[i] *= fir_window[i];
    free(fir_window);
void create_fir_notch(float *coeffs, int len, float notch_freq, float sample_rate) {
    // Factor de normalización de frecuencia (0 a 0.5)
    float ft = notch_freq / (sample_rate / 2);
    // Generar una ventana para suavizar el filtro (Blackman es una buena elección)
    float window[len];
    dsps_wind_blackman_f32(window, len);
    for (int i = 0; i < len; i++) {
        // Fórmula para el filtro notch centrado en `notch_freq`
        if (i == len / 2) {
            coeffs[i] = 1.0 - 2.0 * ft;
            coeffs[i] = -sin(2 * M_PI * ft * (i - len / 2)) / (M_PI * (i - len / 2));
        coeffs[i] *= window[i]; // Aplicar ventana
static __attribute__((aligned(16))) float tone_combined[FIR_BUFF_OUT_LEN];
static __attribute__((aligned(16))) float fir_coeffs[FIR_COEFFS_LEN];
static __attribute__((aligned(16))) float delay_line[FIR_COEFFS_LEN];
void app_main()
    const int32_t fir_len = FIR_COEFFS_LEN;
    const float fir_ft = 0.5 / DECIMATION;                                  // Transition frequency of the FIR filter
    const int32_t N = N_SAMPLES;                                            // Number of input samples
    const int32_t fir_decim = DECIMATION;                                   // FIR filter decimation
    const int32_t N_buff = FIR_BUFF_OUT_LEN;                                // Total length of samples with ignored
    fir_f32_t fir1;
    esp_err_t ret;
    // Ignoring the first set of samples, due to the delay line of the FIR filter
    const int fir_out_offset = ((FIR_DELAY / 2) - 1);
    ESP_LOGI(TAG, "Start Example.");
    // If a user doesn't care about buffer allocation, the default
    // initialization could be used as shown here:
    ret = dsps_fft2r_init_fc32(NULL, CONFIG_DSP_MAX_FFT_SIZE);
    if (ret  != ESP_OK) {
        ESP_LOGE(TAG, "Not possible to initialize FFT. Error = %i", ret);
        return;
    ret = dsps_fft4r_init_fc32(NULL, CONFIG_DSP_MAX_FFT_SIZE);
        return;
    // Generate input signal as 2 sine waves
    //float *tone_1 = (float *)malloc(N_buff * sizeof(float));
    float *tone_2 = (float *)malloc(N_buff * sizeof(float));
    //dsps_tone_gen_f32(tone_1, N_buff, 5, 0.2, 0);
    // Generate windowing coefficients
    float *window = (float *)malloc(N * sizeof(float));
    dsps_wind_blackman_harris_f32(window, N);
    // Add the two waves together
    /*for (int i = 0 ; i < N_buff ; i++) {
        tone_combined[i] =  tone_2[i];
while(true){
	        printf("%f\n", tone_combined[i]);
return;*/
    //free(tone_1);
    //free(tone_2);
    // Apply the windowing
    for (int i = 0 ; i < N ; i++) {
        //window[i] *= tone_combined[i];
        window[i] *= tone_2[i];
    // Show FFT spectrum
    show_FFT(window, N);
return;
    // Calculate coefficients for the FIR filter
    generate_FIR_coefficients(fir_coeffs, fir_len, fir_ft);
    ESP_LOGI(TAG, "\n");
    // Filter the input signal with FIR filter
    float *fir_out = (float *)malloc( N_buff * sizeof(float));
    dsps_fird_init_f32(&fir1, fir_coeffs, delay_line, fir_len, fir_decim);
    uint32_t start_b = dsp_get_cpu_cycle_count();
    dsps_fird_f32(&fir1, tone_combined, fir_out, N_buff / fir_decim);
    uint32_t end_b = dsp_get_cpu_cycle_count();
    // Generate windowing coefficients and apply the windowing
    dsps_wind_blackman_harris_f32(window, (N / fir_decim));
    for (int i = 0 ; i < N / fir_decim ; i++) {
        window[i] *= fir_out[fir_out_offset + i];
    // Show FFT spectrum, ignoring first samples from the delay line
    show_FFT(window, N / fir_decim);
    ESP_LOGI(TAG, "FIR for %"PRId32" samples and decimation %"PRId32" takes %"PRId32" cycles", N, fir_decim, (int32_t)(end_b - start_b));
    ESP_LOGI(TAG, "End Example.");
    free(fir_out);
    free(window);
ESP_Sprite
Re: Problem with esp_dsp library
Postby ESP_Sprite » Sat Nov 16, 2024 12:27 am
That looks suspiciously like aliasing: note the second peak is at (sampling freq - 400Hz). My coffee isn't entirely working so I cannot immediately figure out why it happens here, but it's probably an artifact rather than something wrong with the sinewave.
Kniroxe
Postby Kniroxe » Mon Nov 18, 2024 7:34 pm
Hi, the problem is: why doesn't the dsps_tone_gen_f32 function work? It is an official function, and the example I used is provided by Espressif. It should work fine since I only modified it to generate one signal instead of two.
ESP_Sprite
Postby ESP_Sprite » Tue Nov 19, 2024 1:10 am
It does work, you can see that it generates a perfectly fine sine in your first image. It's the way you pull a FFT from it and interpret that FFT which is the issue. If you don't believe me, manually generate a tone and put that through the same FFT and you'll get the same image.
Users browsing this forum: Google [Bot], Vishna and 142 guests
