suspending and resuming NimBLE Task
aygh4266
Postby aygh4266 » Fri Nov 15, 2024 12:40 pm
Hello everyone,
I want to activate bluetooth only for a while and when it is only necessary. Should it be better to suspend and resume the NimBLE freertos task based on :
void vAFunction( void )
    TaskHandle_t xHandle;
    // Create a task, storing the handle.
    xTaskCreate( vTaskCode, "NAME", STACK_SIZE, NULL, tskIDLE_PRIORITY, &xHandle );
    // Use the handle to suspend the created task.
    vTaskSuspend( xHandle );
    // The created task will not run during this period, unless
    // another task calls vTaskResume( xHandle ).
    // Resume the suspended task ourselves.
    vTaskResume( xHandle );
    // The created task will once again get microcontroller processing
    // time in accordance with its priority within the system.
or to initialize and deinitialize the nimble port based on:
void start_bt_task() {
    nimble_port_init();
    nimble_port_freertos_init(your_host_task_fn);
void stop_bt_task() {
    nimble_port_stop();
    nimble_port_deinit();
    nimble_port_freertos_deinit();
MicroController
Re: suspending and resuming NimBLE Task
Postby MicroController » Fri Nov 15, 2024 1:05 pm
The latter.
A task should never suspend any task other than itself.
Users browsing this forum: No registered users and 143 guests
