Hello, I'm experiencing issues while migrating to the new ESP-IDF I2C driver (in ESP-IDF 5.3.1). The problem arises when I try to use the bus in asynchronous mode. Due to limited documentation and the recent implementation of the new driver, I found only one example indicating that to enable async mode, you need to set the "trans_queue_depth" parameter (in the bus config structure of type i2c_master_bus_config_t) to a value other than zero.
When I set this parameter, I can see the bus operating in async mode. However, after some time, the ESP resets with a "Guru Meditation Error."
Another issue is that I’m not entirely sure what value to set for "trans_queue_depth" or exactly how this buffer (assuming it is a buffer) operates, especially since the amount of data I send over the bus varies with each transmission.
I would appreciate any examples or documentation on how to use the I2C driver in asynchronous mode. For context, I'm using the bus to send data to an OLED screen.
Regards.
Issues with new I2C driver.
Jump to
- English Forum
- Explore
- News
- General Discussion
- FAQ
- Documentation
- Documentation
- Sample Code
- Discussion Forum
- Hardware
- ESP-IDF
- ESP-BOX
- ESP-ADF
- ESP-MDF
- ESP-WHO
- ESP-SkaiNet
- ESP32 Arduino
- IDEs for ESP-IDF
- ESP-AT
- ESP IoT Solution
- ESP RainMaker
- Rust
- ESP8266
- Report Bugs
- Showcase
- Chinese Forum 中文社区
- 活动区
- 乐鑫活动专区
- 讨论区
- 全国大学生物联网设计竞赛乐鑫答疑专区
- ESP-IDF 中文讨论版
- 《ESP32-C3 物联网工程开发实战》书籍讨论版
- 中文文档讨论版
- ESP-AT 中文讨论版
- ESP-BOX 中文讨论版
- ESP IoT Solution 中文讨论版
- ESP-ADF 中文讨论版
- ESP Mesh 中文讨论版
- ESP Cloud 中文讨论版
- ESP-WHO 中文讨论版
- ESP-SkaiNet 中文讨论版
- ESP 生产支持讨论版
- 硬件问题讨论
- 项目展示
Users browsing this forum: Baidu [Spider] and 393 guests
- All times are UTC
- Top
- Delete cookies
About Us
