Error Install Eclipse Plugin
Edmundo
Postby Edmundo » Tue Nov 12, 2024 9:16 am
I am using Windows 10, Eclipse Version Version: 2024-09 (4.33.0), Python 3.13.0 and the ESP-IDF Eclipse Plugin Version: 3.1.0.202410070705.
The ESP-IDF-Manager correctly finds the paths of Python and git executables.
After downloading many things the installation process stops always aborts with the following message:
  • Cannot import module "click". This usually means that "idf.py" was not spawned within an ESP-IDF shell environment or the python virtual environment used by "idf.py" is corrupted.
    Please use idf.py only in an ESP-IDF shell environment. If problem persists, please try to install ESP-IDF tools again as described in the Get Started guide.
I have checked it for the version ESP-IDF version v5.3.1 and Master.
Any ideas?
Kind regards,
Roman
Edmundo
Re: Error Install Eclipse Plugin
Postby Edmundo » Wed Nov 13, 2024 7:34 pm
I found 2 related things.
1.
The last error message in the Eclipse Console is as follows:
  • Executing C:\Users\Edmundo\.espressif\python_env\idf5.3_py3.13_env/Scripts/python.exe d:\tools\eclipseidf\esp-idf-v5.3.1\tools\idf.py --list-targets
As shown the command idf.py --list-targets is called with the complete path of python.exe.
If I open a configured and running ESP-IDF 5.3 PowerShell (installed with the offline manual install method) and start a simple idf.py it works as expected. Add the complete path as it is done in Eclipse fails with the same error.
So I assume that it s
  • # simple idf.py
    PS C:\Espressif\frameworks\esp-idf-v5.3.1> idf.py --list-targets
    esp32
    esp32s2
    esp32c3
    esp32s3
    esp32c2
    esp32c6
    esp32h2
    esp32p4
    # complete path to idf.py
    PS C:\Espressif\frameworks\esp-idf-v5.3.1> C:\Users\Roman\.espressif\python_env\idf5.3_py3.13_env/Scripts/python.exe d:\tools\eclipseidf\esp-idf-v5.3.1\tools\idf.py --list-targets
2.
The same error happens in Espressif-IDE if an existing ESP-IDF is imported by with the IDF Manager.
I have a running VSCODE based ESP installation and also the manual ESP Offline installation that includes the Eclipse based Espressif-IDE.
If I try to add the existing VSCODE ESP-IDF from inside the IDF Manager of the Expressif IDE by "Choose existing ESP-Directory" i get the same red marked error message shown above shortly appears but the process does not stop.
At the end I see the requested ESP targets.
My assumption: The problem is that idf.py is called with the complete path.
Many thanks for reading this and best regards,
Edmundo
Users browsing this forum: No registered users and 38 guests
