Getting random USB_UART_CHIP_RESET
AndreaS73
Postby AndreaS73 » Mon Nov 11, 2024 11:32 am
I made several prototypes of my custom board that is powered by external power supply and uses the USB connection (USB_D+, USB_D-) for programming and UART only.
I'm sure I'm doing something wrong in my firmware (quite large) because since few days I'm getting random resets with the cause `USB_UART_CHIP_RESET`:
Of course I'm trying to comment out some part of my code to find the culprit, but I wonder what can cause such a reset so I can search in the right direction.
I use the USB port for sending out messages, with `ESP_LOGI` for example, or to receive data using the `usb_serial_jtag`driver:
usb_serial_jtag_driver_config_t usb_serial_jtag_config =
        .rx_buffer_size = NMEA_BUFFER_SIZE,
        .tx_buffer_size = NMEA_BUFFER_SIZE,
    usb_serial_jtag_driver_install(&usb_serial_jtag_config);
    usb_serial_jtag_vfs_register();
    usb_serial_jtag_vfs_use_driver();
    uart_vfs_dev_register();
and
int len = usb_serial_jtag_read_bytes(buffer, (BUFFER_SIZE - 1), 20 / portTICK_PERIOD_MS);
called every 50 ms.
What can cause such a reset?
aliarifat794
Re: Getting random USB_UART_CHIP_RESET
Postby aliarifat794 » Mon Nov 11, 2024 12:44 pm
Verify buffer sizes (NMEA_BUFFER_SIZE and BUFFER_SIZE) and ensure they align with the expected data flow. If buffers are too small, there may be overflow issues, especially if logging at high rates.
AndreaS73
Postby AndreaS73 » Tue Nov 12, 2024 3:24 pm
Found the problem.
It was the cable, a faulty cable.
Users browsing this forum: No registered users and 157 guests
