LilyGO T-Display-S3 and photoelectric sensor
plotto
Postby plotto » Sat Nov 09, 2024 4:31 am
Hi, new to the forum.
I have a LilyGO T-Display-S3 and have the touch screen and the UI all functioniung correctly.
I am strugling with the pins and connecting the photoelectric sensor and getting it to work.
Which pins to use seems a little confusing, or it may be my noob coding skills.
If any one has some advise or help on getting this to work it would be much appreciative.
#include <lvgl.h>
#include <TFT_eSPI.h>
#include <ui.h>
#include <CST816S.h>
static const uint16_t screenWidth  = 170;
static const uint16_t screenHeight = 320;
static lv_disp_draw_buf_t draw_buf;
static lv_color_t buf[ screenWidth * screenHeight / 10 ];
unsigned long previousMillis = 0;
const long interval = 1000;
int current=0;
int number=0;
int sensor=18;
int actuator=20;
int count=0;
TFT_eSPI tft = TFT_eSPI();
CST816S myTouch(18, 17, 21, 16);
#if LV_USE_LOG != 0
void my_print(const char * buf)
    Serial.printf(buf);
    Serial.flush();
#endif
void my_disp_flush( lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p )
    uint32_t w = ( area->x2 - area->x1 + 1 );
    uint32_t h = ( area->y2 - area->y1 + 1 );
    tft.startWrite();
    tft.setAddrWindow( area->x1, area->y1, w, h );
    tft.pushColors( ( uint16_t * )&color_p->full, w * h, true );
    tft.endWrite();
    lv_disp_flush_ready( disp );
void my_touchpad_read( lv_indev_drv_t * indev_driver, lv_indev_data_t * data )
    uint16_t touchX = 0, touchY = 0;
  if (myTouch.available()) {
    touchX = myTouch.data.x;
    touchY = myTouch.data.y;
    data->state = LV_INDEV_STATE_PR;
    data->state = LV_INDEV_STATE_REL;
  data->point.x = touchX;
  data->point.y = touchY;
  if (touchX != 0) {
    Serial.print("Data x ");
    Serial.println(touchX);
  if (touchY != 0) {
    Serial.print("Data y ");
    Serial.println(touchY);
void setup()
    Serial.begin( 115200 );
    String LVGL_Arduino = "Hello Arduino! ";
    LVGL_Arduino += String('V') + lv_version_major() + "." + lv_version_minor() + "." + lv_version_patch();
    Serial.println( LVGL_Arduino );
    Serial.println( "I am LVGL_Arduino" );
    lv_init();
pinMode(sensor, INPUT);
pinMode(actuator, OUTPUT);
#if LV_USE_LOG != 0
    lv_log_register_print_cb( my_print );
#endif
    tft.begin();
    tft.setRotation( 0 );
    myTouch.begin();
    lv_disp_draw_buf_init( &draw_buf, buf, NULL, screenWidth * screenHeight / 10 );
    static lv_disp_drv_t disp_drv;
    lv_disp_drv_init( &disp_drv );
    disp_drv.hor_res = screenWidth;
    disp_drv.ver_res = screenHeight;
    disp_drv.flush_cb = my_disp_flush;
    disp_drv.draw_buf = &draw_buf;
    lv_disp_drv_register( &disp_drv );
    static lv_indev_drv_t indev_drv;
    lv_indev_drv_init( &indev_drv );
    indev_drv.type = LV_INDEV_TYPE_POINTER;
    indev_drv.read_cb = my_touchpad_read;
    lv_indev_drv_register( &indev_drv );
    ui_init();
    Serial.println( "Setup done" );
void increase(lv_event_t * e)
  number++;
void reset(lv_event_t * e)
  number=0;
  count=0;
  current=0;
void loop()
   unsigned long currentMillis = millis();
    lv_timer_handler();
    delay(5);
    _ui_label_set_property(ui_Label1, _UI_LABEL_PROPERTY_TEXT, String(number).c_str());
    _ui_label_set_property(ui_Label5, _UI_LABEL_PROPERTY_TEXT, String(current).c_str());
int buttonState = digitalRead(sensor);
if (buttonState = LOW)
count++;
current++;}
if (count>=number)
digitalWrite(actuator, 1);
  if (currentMillis - previousMillis >= interval) {
    previousMillis = currentMillis;
    if (digitalRead(actuator == 1)) {
digitalWrite(actuator, 0);}
else {digitalWrite(actuator, 1);
count=0;}
aliarifat794
Re: LilyGO T-Display-S3 and photoelectric sensor
Postby aliarifat794 » Sat Nov 09, 2024 11:06 am
It looks like there are some errors in the code. Please correct it:
#include <lvgl.h>
#include <ui.h>
int current = 0;
int number = 0;
int sensor = 18;       // Adjust if needed
int actuator = 20;     // Adjust if needed
int count = 0;
#if LV_USE_LOG != 0
void my_print(const char * buf) {
    Serial.printf(buf);
    Serial.flush();
#endif
void my_disp_flush(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p) {
    uint32_t w = (area->x2 - area->x1 + 1);
    uint32_t h = (area->y2 - area->y1 + 1);
    tft.startWrite();
    tft.setAddrWindow(area->x1, area->y1, w, h);
    tft.pushColors((uint16_t *) &color_p->full, w * h, true);
    tft.endWrite();
    lv_disp_flush_ready(disp);
void my_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data) {
    if (touchX != 0) {
    if (touchY != 0) {
    lv_init();
#if LV_USE_LOG != 0
    lv_log_register_print_cb(my_print);
#endif
    tft.begin();
    tft.setRotation(0);
    myTouch.begin();
    lv_disp_draw_buf_init(&draw_buf, buf, NULL, screenWidth * screenHeight / 10);
    lv_disp_drv_init(&disp_drv);
    lv_disp_drv_register(&disp_drv);
    lv_indev_drv_init(&indev_drv);
    lv_indev_drv_register(&indev_drv);
    ui_init();
    Serial.println("Setup done");
void increase(lv_event_t * e) {
    number++;
void reset(lv_event_t * e) {
    number = 0;
    count = 0;
    current = 0;
    lv_timer_handler();
    delay(5);
    if (buttonState == LOW) {
        count++;
        current++;
    if (count >= number) {
        digitalWrite(actuator, HIGH);
        if (digitalRead(actuator) == HIGH) {
            digitalWrite(actuator, LOW);
            count = 0;
Users browsing this forum: No registered users and 114 guests
