si7210 sensor data read
fabi1415
Postby fabi1415 » Tue Oct 22, 2024 12:22 pm
Can someone help me. I always receive the same value.
#include <Wire.h>
#include <Arduino.h>
#define reg_chip 0xC0
#define reg_hByte 0xC1
#define reg_lByte 0xC2
#define otp_data_addr 0xE2
#define SLAVEaddr 0x30
void initializeSensor() {
    Wire.beginTransmission(SLAVEaddr);
    Wire.write(0xC9);
    Wire.endTransmission(false);
    delay(100);
void setreg() {
    Wire.write(0x04);
    Wire.write(0x01);
    delay(1);
void setup()
  Wire.begin(21,22);
  delay(1000);;
  initializeSensor();
  // iwc address scanner
  byte error, address;
  for (address = 1; address < 127; address++)
    Wire.beginTransmission(address);
    delay(100);
    error = Wire.endTransmission();
    delay(1);
    if (error == 0)
      Serial.print("I2C device found at address 0x");
      if (address < 16)
        Serial.print("0");
      Serial.print(address, HEX);
      Serial.println("  !");
  // Read ChipID
  Wire.write(0x04);
  Wire.write(0x01);
  Wire.write(reg_hByte);
  byte result = Wire.endTransmission();
  delay(100);
  Wire.requestFrom(SLAVEaddr, 1);
  delay(100);
  byte chipID = Wire.read() >> 4;
  delay(100);
  Serial.print("ChipID: ");
  Serial.println(chipID, DEC);
void loop()
  int16_t field;
  float result;
  float scale = 204.7f;
  // Read high byte
  Wire.write(0x04);
  Wire.write(0x01);
  delay(100);
  delay(1);
  byte highByte = Wire.read();
  delay(100);
  // read low byte
  Wire.write(0x04);
  Wire.write(0x01);
  Wire.write(reg_lByte);
  delay(100);
  delay(1);
  byte lowByte = Wire.read();
  delay(100);
  field = ((highByte & 0x7F) << 8) | lowByte;
  field -= 16384;
  result = (256*highByte+lowByte -16384)* (0.00125);
  Serial.println(result);
  delay(1000);
output:
[  1129][E][Wire.cpp:416] beginTransmission(): Unfinished Repeated Start transaction! Expected requestFrom, not beginTransmission! Clearing...
I2C device found at address 0x30  !
ChipID: 0
-20.48
-20.48
-20.48
-20.48
-20.48
-20.4
8
Users browsing this forum: iParcelBox, jjsch-dev and 99 guests
