PSRAM octal menuconfig pin value
Olfox59
Postby Olfox59 » Tue Oct 15, 2024 9:33 am
Hi I try to cnifgure for my board the external psram 8MB of my wrrom n16r8 but even if the ram if detected, there is a config issue:
As i have 8MB here, i selected Octal Mode, and it select by default pin30 and 26 for sck and cs, pin that are normally used on my pcb, but i removed the component to be sure for the test.
But as the help mention that it is possible to use any unused gpio, I changed to gpio41 and 42 that are left open, but it seems that range in kconfig for this value are 0-33, so in sdkconfig, my modifications seems to not be effective, and i still see the 30 and 26 value:
How to you do for this wroom kit please ?
Thank you
MicroController
Re: PSRAM octal menuconfig pin value
Postby MicroController » Tue Oct 15, 2024 12:07 pm
Are you trying to change the wiring of the PSRAM on the N16R8 module via software?!
Olfox59
Postby Olfox59 » Tue Oct 15, 2024 12:17 pm
Hehe no,
I'm using esp32s3 wroom1 n16r8 module so...
But i thought it was possible to change the three pins 36 37 38 .
I'm a bit mixing all the informations in my head i will delete the post because you are right i was mixing informations in my head
Users browsing this forum: Baidu [Spider], ESP_ondrej, MicroController and 126 guests
