I installed the last ESP-IDF via the Windows installer as officially recommended. (https://dl.espressif.com/dl/esp-idf)
However, when I start the Expressiv IDE, the autocompletion doesn't work. When I type, I get the following error message:
Error while computing completion
java.util.concurrent.CancelationException
Autocompletion at Expressiv IDE doesn't work
Re: Autocompletion at Expressiv IDE doesn't work
Could you confirm which version of ESP-IDF you are using? The reported issue arises when you’re working with ESP-IDF 4.x and new LSP editor is only supported with the ESP-IDF 5.x and higher.
If possible, please upgrade to ESP-IDF 5.0 or higher.
If for some reason if you need ESP-IDF 4.x and you need to install esp-clang tool manually to work with the new LSP C/C++ editor
https://github.com/espressif/llvm-proje ... 2_20240912
Please check this link on downloading and configuring
https://github.com/espressif/idf-eclips ... 2225815025
Hello !
We were able to reproduce this issue.
Please, for now here is workaround for you:
go to "Espressif" menu -> open "ESP-IDF: Manager" -> delete active ESP-IDF version -> Add same ESP-IDF version.
- Screenshot 2024-10-14 172304.jpg (75.31 KiB) Viewed 1345 times
I am having the same issue, the autocompletion not working:
Users browsing this forum: walkabout and 7 guests
