Bluetooth pairing issue with Legacy mode
Wolpertinger
Postby Wolpertinger » Fri Oct 11, 2024 8:37 am
I'm programming in VS Code with the ESP-IDF. I edited the sdconfig so I can use legacy mode pairing and this all works fine. But for some reason, after cycling the power of my esp my phone asks me to pair again.
So my guess is that the esp does not store the paired devices. Is there a way around this?
Wolpertinger
Re: Bluetooth pairing issue with Legacy mode
Postby Wolpertinger » Fri Oct 25, 2024 7:40 am
Does nobody have any idea?
Here is my initialisation logic:
esp_bt_controller_config_t bt_cfg = BT_CONTROLLER_INIT_CONFIG_DEFAULT();
    ret = esp_bt_controller_init(&bt_cfg);
    ret = esp_bt_controller_enable(ESP_BT_MODE_CLASSIC_BT);
    ret = esp_bluedroid_init();
    ret = esp_bluedroid_enable();
    ret = esp_spp_register_callback(bt_spp_event_handler);
    esp_spp_cfg_t sppConfig = {
        .mode = ESP_SPP_MODE_CB,
        .enable_l2cap_ertm = false,
        .tx_buffer_size = 1024
    ret = esp_spp_enhanced_init(&sppConfig);
    ret = esp_spp_start_srv(ESP_SPP_SEC_NONE, ESP_SPP_ROLE_SLAVE, 0, "SPP_SERVER");
    ret = esp_bt_dev_set_device_name(mySettings.device_name);
    // Setzen der festen PIN für Bluetooth Classic
    ret = esp_bt_gap_set_pin(ESP_BT_PIN_TYPE_FIXED, 4, (uint8_t*)mySettings.BTpin);
    ret = esp_bt_gap_set_scan_mode(ESP_BT_CONNECTABLE, ESP_BT_GENERAL_DISCOVERABLE);
Users browsing this forum: jmogdev, oz1cmdk and 95 guests
